The Dot Product and Cross Product: Finding the Angle Between Two Vectors
The discussion centers on determining the angle theta between two vectors A and B that satisfies the equation A dot B = |A x B|. The correct angle is identified as 315 degrees, which corresponds to a smaller angle of 45 degrees, while 225 degrees corresponds to 135 degrees, making it incorrect. The distinction is made that the formulas for dot and cross products use the smaller angle between the vectors. Additionally, the magnitude of the cross product is clarified, emphasizing that it should be expressed as |A x B| = |A||B| sin(theta). The conversation highlights a potential misunderstanding regarding the accepted range for angles between vectors.
raptik
If theta is the angle between two non-zero vectors A and B, then which of the following angles theta results in A dot B = |A x B|?
A dot B = ABcos(theta)
A x B = ABsin(theta)
There were two choices in the multiple choice answers where cos(theta) = |sin(theta)|
1 is 225 degrees and the other is 315 degrees. The correct answer is 315 degrees. Can somebody explain or help illustrate why 225 is wrong and 315 is right?
When performing the dot and cross product the angle used in the formulas you listed is always the smaller angle between the two vectors. So an angle of 315 degrees corresponds to an angle of 45 degrees (360-315=45). And 225 corresponds to an angle of 135 degrees. This should help you answer your question.
Additionally the Magnitude of the cross product is defined as:
|A x B|= |A||B| sin(theta)
not = |AB sin(theta)| or AB |sin(theta)| as you eluded to in your post.
True as long as we agree that 0° ≤ θ ≤ 180°, as is common practice. But apparently the question's author has a different idea about the angle between two vectors!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
