longchair
- 2
Hi there, new member here
(**TL,DR is available at the bottom of this post**)
As you may or may not know, if you were to put in a plate of zinc at one end and a plate of copper at the other, put them in an acid solution, electricity will be produced.
More of that stuff here: https://en.wikipedia.org/wiki/Lemon_battery
However, it doesn't necessarily have to be copper and zinc. You could use different metals (with different reactivity) including aluminum, lead, silver, etc;
After some experimentation, I found out that different combinations of metals produced different voltages and current, thus different power output as well.
But, do these different combinations of metals produce different amounts of total energy? Or is it that the total energy produce will be the same, and a lower power output results in the system lasting longer.
TL,DR
In the lemon battery (and most other metals), we can use different metals (with different re-activity) to generate electricity. Do all combinations result in the same total output of energy?
Thank you very much for your time
Any response will be appreciated
TL,DR
