Undergrad The Energy - Momentum Equation vs the Energy - Mass Equation
The discussion centers on the energy-momentum equation E² = p²c² + (m₀c²)², which relates energy, momentum, and mass in both stationary and dynamic situations. In a stationary state, the equation simplifies to E₀ = m₀c², while in a dynamic state, it becomes E = mc², indicating the relationship between energy and mass when a particle is in motion. Participants highlight that the concept of relativistic mass has largely been abandoned in modern physics, favoring invariant mass for clarity. The conversation also touches on the confusion surrounding the definitions of mass in relativistic contexts, emphasizing that contemporary physics relies on invariant quantities. Overall, the thread underscores the evolution of understanding in the field of relativity and the importance of using accepted terminology.
  • #61
It's not clear to me, what the criticism is here. One thing is nevertheless mathematically inevitable: There's no analogue of Newtonian mass conservation in special relativity. I don't think that Okun implies that there's a mass-conservation law in relativistic physics though you can interpret the last sentence in the above quoted passage 8.10.
  • #62
In the first sentence of passage 8.10, Okun says (differently to Landau and Lifshitz):
Okun said:
Is mass conserved? With E and P conserved, the mass M of the system (a set) of particles, defined by the formula ##M^2 = E^2 - \mathbf {P}^2##, must be conserved as well.
He does not mention in passage 8.10 an explicit additional mass-conservation law. To my understanding, that is not needed, because the 4-momentum can/shall be regarded as one physical quantity. As for all 4-vectors, the norm equals in case of velocities ##<c## the proper value of the 1st component.
But I also think, in the specific use case with electrons and muons from your posting #39, it is impossible, to measure in a lab directly the invariant mass of that system.
  • #63
But the center-momentum energy ##\sqrt{s}## is also not conserved. Just take some condensed-matter system and heat it up. The center-momentum energy changes by ##\Delta Q/c^2##, where ##\Delta Q## is the transferred heat energy.
Of course you can measure ##\sqrt{s}##. You just need the particle momenta in the incoming channel and then calculate their energies from the on-shell conditions, ##E_j=c \sqrt{m_j^2 c^2+\vec{p}^2}## and then you get ##s=(p_1+p_2)^2=E_{\text{cm}}^2/c^2##.
Likes etotheipi
  • #64
That would not be a closed system. You add energy from outside the system.
Therefore, I wrote "directly". I read from Okun:
On page 58/75 Okun said:
As for the mass of a system of free particles, it is simply their total energy (divided by c²) in a frame in which their total momentum is equal to zero. The value of this mass is limited only by conservation of energy and momentum, like in the case of two photons in the decay of positronium. As a rule we are unable to measure the inertia or gravity of such a system, but the self-consistency of the relativity theory guarantees that it must behave as mass
Source:
http://phys.sunmarket.com/rus/about/virtual/mtg-lomonosov-13/PDF/23.08.07/Morning/Okun.pdf
  • #65
I agree with Okun in his definition of "mass" (though I prefer to use the Mandelstam variables in collision theory; I don't need the notion of "mass" of the total system at all here). I don't know, what he means by to measure inertia to begin with, but of course you can measure the center-momentum energy of two particles in a collision experiment as described above. Gravity is measureable in principle as any field by using test particles. I don't understand, what Okun wants to say with the last sentence in the quote above.
  • #66
I think he means, that you cannot put a system of free particles simply onto a bathroom scale to measure it's inertial mass. You could do it for example with a block of iron, which was heated up before, to show, that also the kinetic energy of the oscillating iron atoms contributes to the inertial mass of the iron block (if the bathroom scale would be sensitive enough).
Likes vanhees71
  • #67
One should also note that energy is not necessarily additive. It's only additive in the limit when mutual interactions of the constituents of a composite system can be neglected as, e.g., for a dilute gas which is with good approximation an ideal gas. Nevertheless the energy of a closed system is conserved.
Likes Sagittarius A-Star
  • #68
Yes. Let me formulate it more precisely as I understand it: Energy is additive for an ideal box, filled with an ideal gas. A statement, if energy is additive, is only meaningful possible, if all parts of the energy can be uniquely assigned to one of each of the constituents. That is usually not possible for non-ideal gas.
  • #69
vanhees71 said:
There is no Minkowski norm, but I understand what you mean. I'd strongly discourage from using this notation, which I've never seen before, because it can only lead to more confusion as we just see in this thread.
There is a Minkowski norm. Maybe you haven't encountered this terminology before but it is described several places on Wikipedia so it is at least not completely unknown to others
https://en.wikipedia.org/wiki/Minkowski_norm
https://en.wikipedia.org/wiki/Minkowski_space
https://en.wikipedia.org/wiki/Minkowski_space#Norm_and_reversed_Cauchy_inequality
https://en.wikipedia.org/wiki/Four-momentum#Minkowski_norm
Nevertheless, for this thread I will avoid it to avoid unnecessary disputes. I like the notation because it emphasizes the geometry, and because it is easier to write in LaTeX. But I will go the long route in this thread.
vanhees71 said:
Mass is NOT conserved, energy is in special relativity. Mass is NOT additive but energy is.
I am not sure what concept of mass you are referring to here.
##\sqrt{(\Sigma p_{\mu})(\Sigma p^{\mu})}##, the system invariant mass, IS conserved and is NOT additive
##\Sigma(\sqrt{p_{\mu}p^{\mu}})##, the sum of the invariant masses, is NOT conserved and IS additive
##\Sigma p^0##, the relativistic mass, IS conserved and IS additive
Could you clarify which concept of mass you refer to that is NOT conserved and is NOT additive?
Likes dextercioby
  • #70
@PeroK : Did you notice? It was not me, who wrote this. :smile:
  • #71
I still do not think that one should talk about a norm, and I don't agree with Wikipedia in this case. In mathematics it least the norm has a well defined meaning, and only a proper scalar product (positive definite bilinear form for real or positive definite sequilinear form for complex vector spaces) can induce a norm on vector spaces, but that's semantics.
We agree about the definition of mass of a composite system of non-interacting particles as ##\sqrt{s}## as defined by your first sqrt. We agree also about invariant masses. I don't agree with the use of "relativistic mass". I thought we have an agreement in this forum that we discourage the use of this outdated notion.
Also concerning the additivity of energy one has to be careful (see the example with the non-ideal gas above).
  • #72
I didn't notice it. I was watching the tennis!
  • Wow
Likes Motore and Sagittarius A-Star
  • #73
We do, I am just trying to figure out what notion of mass *you* were referring to saying that it was both NOT conserved and NOT additive. What were you referring to? Please clarify your meaning of "mass" from post 48: https://www.physicsforums.com/threa...-the-energy-mass-equation.993839/post-6397471
  • #74
For me mass is always invariant mass. Setting ##c=1## for a composite system it's by definition
$$M^2=(\sum p_i)^2.$$
In scatterings the total energy is conserved but not the sum of the masses of the particles. The consevation of ##M=\sqrt{s}## is however energy conservation when considered in the cm frame. In this sense there's no additional mass-conservation law as in Newtonian physics.
  • #75
Then your statement of post 48 is incorrect. With that definition of mass (which is in my opinion the best definition) mass IS conserved but it is NOT additive.
vanhees71 said:
In scatterings the total energy is conserved but not the sum of the masses of the particles. In this sense there's no additional mass-conservation law as in Newtonian physics.
Yes but the sum of the masses of the parts is not the mass, per your definition above. The quantity you identified above as the mass IS conserved. So saying that mass is NOT conserved is not correct using your terminology. What would be correct is the following:
Mass IS conserved but it is NOT additive. Because mass is NOT additive the sum of the masses of the parts is NOT conserved.
Likes vanhees71 and Motore
  • #76
Yes, you are right! In SR, there is no additional mass conservation law as an eleventh independent conservation law of the general Noether conserved quantities following from spacetime symmetries but, if you define the mass of a composite system as above, it's subsumed in the energy-conservation law since the so defined mass is nothing than the energy in the center-momentum frame. In a sense, it's superfluous to define this as mass.
Mass is not conserved in the sense that the so defined "mass" is not the sum of the masses of the components. Indeed, mass is not additive. I think this is all semantics. The important thing is the different mathematical nature of mass in Newtonian physics (central charge of the Galilei group) and special-relativistic physics (Casimir operator of the Poincare group).
BTW: energy is also additive only for non-interacting "constituents". That's already so in Newtonian physics.
  • #77
I'd just like to point out that the pre-relativistic notions of the word mass are responsible for the confusion here.
We were all on the same page from the beginning that a system's mass is its rest-frame energy, and yet the idea of "total mass" (sum of constituent masses) somehow slipped into the conversation, even though nobody was talking about it.
"Total mass" is as useless and silly as "total velocity," but nobody would think to sum the velocities of a system's constituents when asked for the system's velocity.
"Rest energy" sidesteps that temptation altogether. It wouldn't even occur to anyone to start summing up constituent rest-energies if asked to give a system's rest energy. "Total rest energy" isn't an idea that would tacitly worm its way into the discussion. It's a bizarre turn of phrase that wouldn't come to mind at all, and that's a good thing.
  • #78
Yes, and I think the solution to all this confusion is just to avoid "mass" in relativity whenever you mean "rest energy". Then call it rest energy, because that's what it is, and then it's a scalar and no confusion occurs.
  • #79
Yes, that's exactly my point. But what could one possibly mean by (invariant) "mass" other than "rest energy"?
  • #80
I prefer the term “invariant mass” over “rest energy”:
1) Many systems have no rest frame
2) Many systems have non-inertial rest frames
3) The quantity can be determined in any frame using that frame’s data
4) The quantity is invariant
5) Calling it rest energy gives a false sense that it is additive like energy
The term “center of momentum frame energy” resolves several of those but I am lazy and prefer to type 4 characters over 31. So my strong preference is simply to use the term “mass” as a default and “invariant mass” when I am concerned that it may be ambiguous.
Likes dextercioby and vanhees71
  • #81
I couldn't agree more.
6) Calling it rest energy were a misnomer for a(n asymptotic) free photon state, because it's never at rest because its invariant mass is 0.
Likes Dale
  • #82
I agree that "invariant" (or perhaps "proper") is a better adjective than "rest." I only use "rest energy" instead of "invariant energy" or "proper energy" because that's the term for ##mc^2## that I've typically seen in the literature.
Interesting. I always felt the opposite: calling it "[descriptor] energy" gives (me) the right sense that, like "kinetic energy" and "potential energy," it's just one category of energy-contribution that must be accounted for when reckoning a system's (total) energy.
  • #83
SiennaTheGr8 said:
I agree that "invariant" (or perhaps "proper") is a better adjective than "rest." I only use "rest energy" instead of "invariant energy" or "proper energy" because that's the term for mc2 that I've typically seen in the literature.
Since energy is not invariant the term "invariant energy" would be highly confusing. I guess that people understand other oxymorons so it could be adopted eventually, but it is jarring to me.
Additivity isn't about the categories of energy, it is about the energy of the parts and the whole. For a system with non-interacting parts, the kinetic energy of the system is the sum of the kinetic energies of its parts, and the potential energy of the system is the sum of the potential energies of its parts. But even with non-interacting parts the rest energy of a system is not the sum of the rest energies of its parts.
Likes vanhees71
  • #84
Energy is only additive in that sense if the interaction between the constituents can be neglected. I'd not emphasize additivity too much. It's important though in thermodynamics/statistical physics when you find a way to handle a many-body system in some (often tricky) sense as an ideal gas. Then the total energy is indeed the sum over the energy of the constituents (particles, molecules, light quanta or, quasi particles). Already for a real gas the energy is not additive anymore in this sense.
After all this discussion, my conclusion is that the important difference between Newtonian and special relativistic physics is that as analyzed in terms of the space-time symmetry groups/Lie algebras, in Newtonian physics there's an additional conservation law for mass (i.e., there are 11 conservation laws from the physical realization of Galilei symmetry, i.e., a non-trivial central extension of the classical Galilei group, rather than 10 conservation laws from the physical realization of the Poincare group, which has no non-trivial central extensions), while there's none such additional conservation law in special relativistic physics.
Indeed, as @Dale said in the previous posting, the important difference between energy and mass is that the former is a temporal component of a four-vector (energy-momentum four vector) of a closed system while mass is a scalar and associated with the energy in the center-momentum frame of this closed system. Since one can always calculate everything in the center-momentum frame, and there the invariant mass is just the total energy of the system, its conservation is just energy conservation when considered in this preferred (necessarily always inertial!) reference frame of a closed system.
It's of course a very delicate issue to discuss open composite systems. Even a covariant formulation of total energy and momentum as a four-vector is not unique in such a case. This lead to an age-old famous debate about the infamous factor-4/3 problem in the radiation-reaction problem for charged point-particle-like bodies. For that issue, see the very illuminating discussion in Chpt. 16 of Jackson's Classical Electrodynamics. It's amazing that there is still so much debate about this since the entire problem was analyzed completely by von Laue in 1911. The naive expression for the total four-momentum of a continuous system (like continuum mechanics or fields like the em. field)
$$P^{\mu}=\int_{\mathbb{R}^3} \mathrm{d}^3 x T^{\mu 0}(t,\vec{x})$$
is a four vector only if the local conservation law
$$\partial_{\nu} T^{\mu \nu}=0$$
holds, and then ##P^{\mu}## is also conserved (i.e., time-independent), i.e., it's only a proper four-momentum if the system is closed (concerning the exchange of energy and momentum).
To define in a covariant way energy and momentum of an open composite system one has to choose an appropriate preferred reference frame and then transform the energy and momentum from this inertial frame to an arbitrary other inertial frame or write the corresponding integral over the entire spatial volume as observed in the preferred frame in a manifestly covariant way. Then one still has to be careful how to interpret the so defined energy-momentum four-vector in each specific case. All this is nicely discussed by Jackson.
Likes SiennaTheGr8 and Dale
  • #85
If one would follow the usual naming scheme of the 4-position vector (norm = "space-time distance", which equals for ##v<c## to "proper time ##\tau##", then regarding the 4-momentum one would say:
Norm =: "energy-momentum magnitude", it equals for ##v<c## to "proper energy ##E_0##".​
Then "invariant mass" is only an agreed alias name for the (invariant) "energy-momentum magnitude".
If a bug is walking on a bathroom scale, the scale displays its (non-invariant) energy ##E = \gamma * E_0##. If the bug stops, the scale displays its energy in its CoM frame (="proper energy ##E_0##", which equals in this case to the invariant "energy-momentum magnitude" alias "invariant mass").
  • #86
Seems like a distinction without a difference (you get the same total either way you choose to look at it, precisely because energy is additive).
My point was really that before I learned SR, I was already quite accustomed to summing kinetic- and potential-energy contributions to get a system's total energy. For me, the "rest energy" concept fit nicely into that scheme of things, and absolutely didn't give me the wrong idea that a system's rest energy should be the sum of its constituents' rest energies. The opposite, in fact, and it was my prior experience with the word "mass" that was throwing me off.
Different strokes, clearly.
I guess it depends on what you mean by "a system with non-interacting parts," but I don't think that's accurate. Any system has zero kinetic energy in its center-of-momentum frame, regardless of the kinetic energies of its constituents. The sum of kinetic energies alone isn't generally an interesting quantity.
  • #87
Well, as long as thermodynamics is not an interesting part of physics...
Likes vanhees71 and etotheipi
  • #88
Consider a rotating disk. In the center of momentum inertial frame it has non-zero KE. The KE of the disk is equal to the sum of the KE of the various parts of the disk. The rest energy of the disk is greater than the sum of the rest energies of the various parts of the disk. Hence the KE is additive, the rest energy is not.
  • #89
And the sum of a system's constituents' masses is interesting in the Newtonian limit, but that's not what we're talking about. By "generally" I meant "in the general case in SR."
The definition of relativistic kinetic energy I had in mind is ##(\gamma - 1) E_0##, where ##\gamma## is the system's COM-frame's Lorentz factor (relative to some observer's inertial frame), and ##E_0## is the system's rest energy (with the caveat that ##E_0## is not a straightforward quantity to define for an open composite system, related to points @vanhees71 raised above). By that definition, the rotating disk has zero kinetic energy in its center-of-momentum frame, period. Of course, the disk has more total energy when rotating, but as that's all attributable to the kinetic energies of its constituents (in the COM frame), I'd include it in the system's "proper energy" (i.e., its mass).
Anyway, a simple example of what I really had in mind is the COM frame of a system that consists of two electrons moving in opposite directions at identical speeds. The system's kinetic energy in this frame is zero, which is obviously not the sum of its constituents' kinetic energies.
  • #90
OK, but that seems like a pretty odd definition of KE. With that (to me very strange) definition of KE I do see how you would not consider KE additive.
So I guess the disagreement is semantic, but I certainly think my semantics are better. I don’t accept your definition for KE at all.
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 36 ·
  • · Replies 55 ·
  • · Replies 19 ·
  • · Replies 30 ·
  • · Replies 19 ·
