B The energy of a molecule has what sign?
Lotto
TL;DR Summary
Is it negative or positive? I saw it with negative sign. If it is correct, then why is the energy negative?
And have all molecules or even atoms negative energies? So when a molecule have energy let's say -70 Ha and the other -75 Ha, does it mean that the second molecule has a lower energy?
Where did you see it? Show us.
Lotto said:
TL;DR Summary: Is it negative or positive? I saw it with negative sign. If it is correct, then why is the energy negative?
Energy is generally given relative to some arbitrary zero point. E.g. in Newtonian gravity, the zero point for a system of two masses is usually taken to be when the masses are "infinitely" far apart. In which case, the potential energy of the system is given by:$$U = -\frac{Gm_1m_2}{r}$$where ##r## is the distance between the masses. There is no physical significance of this being negative. You could equally take the potential energy to be:$$U = U_0 -\frac{Gm_1m_2}{r}$$for some constant ##U_0##. This would give a value of zero for some finite value of ##r = r_0## and the potential energy would be positive or negative, depending on the value of ##r##.
What's of physical significance is the change in potential energy between two configurations.
Likewise, the electrostatic energy of an atom is generally taken to be relative to some zero point and is often negative. And, yes, ##-75 \ Ha## is less than ##-70 \ Ha##. You need to put ##+10 \ Ha## into the system to change it from the first energy level to the second energy level, in this case.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
