The Foundations of a Non-Naive Mathematics
In summary, Lama is asking the recipient to read a paper about complementary theory and provide detailed remarks and insights. The paper includes a list of axioms, definitions for sets, multiset, singleton sets, urelements, points, and intervals, as well as concepts like symmetry, independency, complementarity, minimal structure, duality, completeness, and phase transition. The recipient is also asked to consider the axiom of abstract/representation relations and the axiom of the paradigm-shift. The diagrams in the paper serve as proofs without words.
  • #211
then you can't define a number "slightly" greater than or "slightly" less than that number, and it has no meaning.
hence irrational
  • #212
You said that 1.1 is slightly different than 1.2.
0.333 is quite a bit closer to 0.333... than 1.1 is to 1.2.
Were you wrong earlier when you said 1.1 is slightly different than 1.2?
And I'll ask again, what does this have to do with 0.333... = 1/3?
  • #213
With your logic terrabyte, you would equally assert that 1/7 = .142857... is a irrational number. Once again this proves your mis-understanding in Math.
You fail to realize that some rational numbers particularly 1/3 and 1/7 in there decimal notation run through a pattern of integers continuously. However irrational numbers have no significant pattern in there decimal notation.
1/3 = .333333333333333333333333333333333333333333333333333333333333333333
1/7 = .142857142857142857142857142857142857142857142857142857142857142857
Pi = 3.141592654,
There is no pattern in Pi, therefore it is irrational and such a number cannot be described as a ratio of two integers. We have only found fractions that closely resemble Pi that our rational. like 22/7 = 3 + 1/7
  • #214
Hurkyl said:
No... one of those is a number; the other two are gibberish.
Anyways, you've evaded my response. None of the approximations I intend to make have an infinite number of nonzero terms, however if you pick any positive value as an allowable tolerance for error, one of my approximations will be within this tolerance.
It seems you are trying to ask me to tell you what the "next" decimal number is, but there is no such thing. (If there was a "next" number, then what happens if I take their midpoint?)
And I'll ask again, what does all of this have to do with whether 1/3 = 0.333...?
the distinction or uniqueness of numbers has infinite precision, meaning no matter how close you come to a number you can ALWAYS cut the distance to reveal another number closer.
that distinction is obliterated by using an infinite string of digits to express a quantity.
case in point our little exercise to determine the closest numbers to .333... the exercize would have worked for any number, i was just using it to illustrate that when we take digits and extend them out to an arbitrar "infinity" we lose the distinction that determines WHAT numbers actually are.
without incrementation, the ability to add MORE digits to further define value, you hit a logical dead end.
this is completely due to the structuring of infinity
you ask how this has to do with .333... and 1/3 well it goes way beyond those two numbers and their properties and into the intrinsic values and quantities of ALL numbers, and the limitations of our mathematical and numerical system.
  • #215
Would you care to prove your point? Give me two decimals representing different quantities, and I'll find a decimal representing a number between them. (One way is I could simply add them and divide by 2)
  • #216
that's the point.
when expanded out to infinite digits you can NOT create different quantities. there is no longer any room for incrementation.
we just did the exercise expanding .32 <.333... <.34 | .332 < .333... < .334
you ran into the same roadblock
  • #217
how old are you terrabyte ? It seems you don't understand anything.
  • #218
terrabyte said:
.333...2 and .333... and .333...4 are all the same number.
there is no designation or incrementation to distiguish their properties of being different numbers because of the current definition limitations of "Infinity"
that's the purpose of the exercise
Still don't understand the definition of infinity, very sad.
  • #219
how old are you to make comments that have no basis on what's being debated?
where is your facts to back up this "argument" that i don't understand anything?
  • #220
Which is fine, because the real numbers don't have incrementation.
You claimed:
I ask you to present two decimals representing different quantities for which I cannot find a decimal between them.
  • #221
instead of hollow "very sad" remarks how about you explain what YOU understand infinity to be and how it fits into the picture.
if you have nothing relevant to say, by all means, keep quiet
  • #222
You can't even accept the definition of irrational neither infinity. Second of all mathematics isn't a question of "debate". This is not a politics forum.
  • #223
We sure seem to have a lot of arrogant, ignorant kids on the forum all of a sudden. Are you all friends? Why are you here?
- Warren
  • #224
you think that .333...4 is a number where there's an infinite of 3's. Tell me how can you add a 4 if there is a NON-ENDING quantity of 3's?
  • #225
real numbers DO have incrementation AND distinction.
every digit 0-9 that is different from one in the same location of another number DEFINES difference.
this is intrinsic AND integral to the structure and utilization of the number system.
when you put a limit on the ability of that system to function of course discrepancies will arise. which is exactly what "Infinity" is. a Limit.
don't come back and say it ISN'T, hello3759 (i know that's going to be your next pithy argument) because it most certainly IS. if it isn't define me a number greater than it.
there isn't one is there?
  • #226
On what grounds do you suggest that? Remember your own statement:
If there was incrementation, then what comes between a number and its increment?
  • #227
Greater than .333... ? no problem
why not 0.4?
  • #228
a smaller increment.
always
  • #229
greater than infinity
  • #230
infinity isn't a number
  • #231
semantics
say something that has meaning, Hello3719, PLEASE
  • #232
why doesn't it has meaning ?
it's true it isn't a number unless you can prove it
  • #233
fine, you stick to that then it's absolutely impossible for you to utilize it as a number.
those are your guidelines.
now express the quantity of how many digits .333... has with values of 3?
  • #234
terrabyte, how much formal mathematics have you actually had? You seem to be a bright, but ignorant, person.
Could you explain this?
Clearly, 0.4 < 0.5 and 0.3983984 < 0.4 and .0000000000003 < 0.00000000000000003, right?
In the case of 0.333... and 0.5454... how is not clear that the latter is greater than the former?
If this isn't what you meant, could you elaborate?
Also, is 1/2 = .5 = .5000...?
How do you technically define rational and irrational numbers?
  • #235
It has as many digits as there are natural numbers.
  • #236
fine, how many natural numbers are there then?
you're just digging a deeper hole :D
  • #237
by notation i am using " ... " to mean never ending quantity of 3's.
why would you say that "never ending" is a number ?
Keep focus.
  • #238
Countably infinitly many...this is going in a cirlce, and I don't see your point.
  • #239
The natural numbers have cardinality [itex]\aleph_0[/itex] and order type [itex]\omega[/itex].
  • #240
rational is expressable EXACTLY as a ratio of two integers. in the case of 1/3 the computation is NOT exact, since it never ends up to and beyond infinity.
thusly the form of expression .333... is not the direct translation of 1/3 from fractional (rational) into decimal (rational) form.
as it stands there IS NO rational decimal form for .333...
and trailing digits 0 such as .50000 <-- have no significance unless used as incremental spacers for digits with value such as .500001 <--
  • #241
By definition, 1/3 is the solution to 3 * x = 1.
3 * .333... = .999... = 1
Thus .333... = 1/3.
  • #242
my point is. it makes no sense to say "infinity is not a number" when it serves as a convenient <yet weightless> argument in a dialog yet proceed to USE it as a quantity in further discussions.
hypocrisy is sometimes deemed the worst of vices...
  • #243
Could you please explain what "EXACT" means in mathematics ?
as i said before , "..." in 0.333... means that there is an infinity of 3's.
Do the division, it is a NON EVER ENDING division where we get a 3 in each step.
  • #244
What do think a ratio is? 1/2 means 1 divided by 2 and 1/3 means 1 divided by 3. Why does the operation of division bother you? Why does division produce something "bad" when you have 1/3 and something "not bad" when you have 1/2? You seem to have a problem with infinity. Why? If you think there's something wrong with infinitly many digits, then the burden is upon you to demonstrate why.
Can you give a formal proof?
Why not? What is special about the digit 0 there isn't there for 3?
Also, you ignored my other questions. I'll repeat them.
How much mathematical training have you actually had?
Clearly, 0.4 < 0.5 and 0.3983984 < 0.4 and .0000000000003 < .00000000000000003, right?
  • #245
terrabyte has been banned. He used to call himself ram1024, ram2048, ram4096, etc. We have banned this person three times already, yet he still does not seem to understand that he is not welcome here, and nor are his pointless threads.
If any of you see activity that you suspect is due to the same individual, please let the staff know so we can deal with it.
- Warren
