Undergrad The gravitational center of the Earth
Gravitational forces are nullified near the Earth's center, making the gravitational field's influence undetectable. The Moon's gravitational field does not shift the area of zero gravity away from the Earth's center; rather, the barycenter of the Earth-Moon system is located about 1,700 km below the Earth's surface. Objects at this barycenter would still experience gravitational attraction towards the Earth's center. The Earth and Moon orbit around this barycenter, but this does not change where gravitational forces cancel out within the Earth. Ultimately, all objects inside the Earth are in free fall relative to the Moon, but not relative to the Earth itself.
qnt200
We know that gravitational forces are nullified near the center of the Earth, so the gravitational field's influence is not felt. Is it because of the Moon's gravitational field that the area of zero gravity has shifted away from the center of the Earth? If this is the case, this eccentric area will orbit around the center of the Earth due to the moon's orbit.
Astronomy news on Phys.org
The gravitational field is never ”felt” in free fall regardless of where you are. Whether the gravitational forces equate to zero depends on your frame of reference.
If you want to consider the Earth-Moon system, them the center of mass is indeed not at the center of the Earth.
The Earth and Moon orbit about the center of mass of the Earth-Moon system. This point, called the barycenter, is about 1,700 km below the Earth's surface.
Likes Ibix, PeroK, Delta2 and 1 other person
However, it's important to stress that an object placed at the barycentre would still be attracted towards the centre of the Earth. I.e. the fact that the Earth and the Moon orbit their mutual centre of mass doesn't affect where the forces produced by the Earth on itself cancel out. This follows from the point Orodruin made - everything on/inside the Earth is in free fall w/r to the Moon, but not w/r to the Earth itself.
UC Berkely, December 16, 2025 https://news.berkeley.edu/2025/12/16/whats-powering-these-mysterious-bright-blue-cosmic-flashes-astronomers-find-a-clue/ AT 2024wpp, a luminous fast blue optical transient, or LFBOT, is the bright blue spot at the upper right edge of its host galaxy, which is 1.1 billion light-years from Earth in (or near) a galaxy far, far away. Such objects are very bright (obiously) and very energetic. The article indicates that AT 2024wpp had a peak luminosity of 2-4 x...
  • · Replies 19 ·
  • · Replies 33 ·
  • · Replies 16 ·
