I The implications of symmetry + uniqueness in electromagnetism
The discussion centers on the implications of symmetry and uniqueness in electromagnetism, particularly regarding a charge distribution that is odd under reflection. The original poster grapples with the conclusion that the electric field must point toward the origin, which contradicts the expected behavior of a dipole. The conversation highlights the need to consider intrinsic symmetries of the electric field, noting that the field components will behave differently under charge-flip and reflection transformations. Ultimately, the correct interpretation leads to a dipole characteristic in the electric field, aligning with the symmetry of the charge distribution. This analysis emphasizes the importance of rigorously applying symmetry principles in electromagnetism.
EE18
I have tried to follow "Symmetry, Uniqueness, and the Coulomb Law of Force" by Shaw (1965) in both asking and solving this question, but to no avail. Some of the mathematical arguments there are a bit too quick for me but, it suffices to say, the paper tries to make the "by symmetry" arguments of introductory electromagnetism rigorous.
My question is the following: Consider a 1D situation in which I have a charge distribution which obeys 𝜌(𝑧)=−𝜌(−𝑧). Then I conclude that there must exist another solution obtained from my original solution via this symmetry: 𝐸′(𝑧)=−𝐸(−𝑧). But by the uniqueness of solutions to electromagnetism problems we have 𝐸′(𝑧)=𝐸(𝑧) so that we have 𝐸(𝑧)=−𝐸(−𝑧). But this is absurd, since it implies that the electric field everywhere points toward the origin which makes no sense for a distribution obeying 𝜌(𝑧)=−𝜌(−𝑧) (dipole) so that it should point in one direction everywhere. Where have I erred in "using symmetry"?
Edit: On reconsidering, I now have the following. We first observe that the symmetry ##\rho(z) = -\rho(-z)## is equivalent to saying that the system must be invariant under a reflection ##\rho(z) \to \rho(-z)## followed by a "flipping" of charge ##\rho(-z) \to -\rho(-z)##. These transformations being symmetries of the system mean that we can obtain another solution to the problem by performing ##E(z) \to E'(z') = E'(-z) = -E(-z)## (this step is analogous to Shaw equation (2)) followed by ##E'(z') \to E''(z') = -E'(z')= -(-E(-z)) = E(-z)##. Then, by uniqueness, it must be that the solution ##E''(z) = E(z)##...but from the above this just says ##E''(z) = E(-(-z)) = E(z)## which is useless (in the last step I have tried to use an analogue to Shaw equation (1)?
I don't have the text you are following, but I think I can follow.
You have a charge density distribution that is symmetric under a charge-flip + reflection about the xy plane, as you have said.
First, you need to consider the intrinsic symmetries of the electric field. Intrinsically, no matter what charge distribution you have, the electric field will flip sign under a charge-flip (since it's proportional to source charge) and the z-component of the E-field will flip sign under reflection about the xy plane (since it is proportional to force and thus acceleration along z). The x and y components of the electric field will be unchanged by the reflection about the xy plane, but they will flip under a charge-flip transformation.
Putting all of that together, you find that your electric field must satisfy:
$$ E_x(-z) = -E_x(z)$$ $$E_y(-z) = -E_y(z)$$ $$E_z(-z) = E_z(z)$$ This field has the dipole characteristic that you were looking for.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
