- #106
PeterDonis
Mentor
- 47,498
- 23,770
Micheth said:I am talking about my original scenario as described above (where C&D are merely the points where lightning bolts will strike when A&B reach them.
Ok; but then I can just define two clocks, E and F, which happen to pass by C and D, respectively, at the exact same instants that clocks A and B reach them and the lightning bolts strike, and which are moving at the exact same speed as A and B are at those instants. Then just substitute E and F for C and D in everything I wrote.
The point I was trying to make with C and D (or E and F in the new nomenclature) was not to construct a new scenario; it was to make it easier to see explicitly aspects of your original scenario that you were not considering. The frame in which E and F are at rest exists, and can be used to analyze your scenario, regardless of whether clocks E and F are actually there. Putting them there just helps to give an actual physical realization of the frame. And A and B end up at rest in that frame--the one I was calling frame CD, and will now call frame EF--regardless of whether clocks E and F are there to compare with. And the procedure I described by which A and B can exchange light signals after they have accelerated and confirm that their clocks are now out of sync and the distance between them has increased, can be done regardless of whether clocks E and F are there.
You can't make the non-synchronization of A and B at the end of your scenario go away by sticking to your original frame (what I call frame AB); once A and B start accelerating, they are no longer at rest in that frame, there's no way around that, so the fact that various events happen at the same time in that frame is no longer relevant for assessing the synchronization of clocks A and B. You can analyze the procedure A and B can follow to exchange light signals after they accelerate in frame AB if you like; it will still tell you that A's and B's clocks are out of sync, in the precise sense I described (the light signals they receive from each other show clock readings that are different than what a synchronized clock would be sending, given the light travel time delay), and that the distance between them has increased (as measured by light travel time).
