The joint probability - two coins
  • Thread starter Thread starter docnet
    Joint Probability
The discussion focuses on calculating the joint probability mass function for two coins, X and Y, revealing values such as p_{X,Y}(1,1) = 3/8 and p_{X,Y}(0,0) = 1/8. It also covers the marginal distributions, showing that p_X(1) and p_X(0) both equal 1/2, while p_Y(1) is 3/4 and p_Y(0) is 1/4. The expected value of Y is calculated as E(Y) = 3/4, and the expected value of (X-0.5)Y is determined to be 0. The conversation highlights the importance of correctly applying probability concepts and formulas, with participants verifying calculations and discussing covariance.
docnet
(a)
The probability mass function of X and Y:
$$p_{X,Y}(1,1)= \frac{1}{2}\cdot \frac{3}{4}=\frac{3}{8}$$
$$p_{X,Y}(1,0)=\frac{1}{2}\cdot \frac{1}{4}=\frac{1}{8}$$
$$p_{X,Y}(0,1)= \frac{1}{2}\cdot \frac{3}{4}=\frac{3}{8}$$
$$p_{X,Y}(0,0)= \frac{1}{2}\cdot \frac{1}{4}=\frac{1}{8}$$
or
p_{X,Y}(a,b)=
\begin{cases}
\frac{3}{8} & (a,b)=(1,1) \quad \text{or}\quad(a,b)=(0,1) \\
\frac{1}{8} & (a,b)=(1,0) \quad \text{or}\quad(a,b)=(0,0)
\end{cases}$$
(b)
The marginal distribution of X is
$$p_X(1)=p_{X,Y}(1,0)+p_{X,Y}(1,1)=\frac{1}{2}\frac{3}{4}+\frac{1}{2}\frac{1}{4}=\frac{1}{2}$$
$$p_X(0)=p_{X,Y}(0,0)+p_{X,Y}(0,1)=\frac{1}{2}\frac{1}{4}+\frac{1}{2}\frac{3}{4}=\frac{1}{2}$$
The marginal distribution of Y is
$$p_Y(1)=p_{X,Y}(0,1)+p_{X,Y}(1,1)=\frac{1}{2}\frac{3}{4}+\frac{1}{2}\frac{1}{4}=\frac{3}{4}$$
$$p_Y(0)=p_{X,Y}(0,0)+p_{X,Y}(1,0)=\frac{1}{2}\frac{1}{4}+\frac{1}{2}\frac{3}{4}=\frac{1}{4}$$
(c)
$$E(Y)=1\cdot p_Y(1)+0\cdot p_Y(0)=\frac{3}{4}$$
(d)
$$E((X-0.5)\times Y)=\sum\limits_{(a,b)}(a-.5)bp_{X,Y}(a,b)$$
$$(1-0.5)(1)p_{X,Y}(1,1)+(1-0.5)(0)p_{X,Y}(1,0)+$$
$$(0-0.5)(1)p_{X,Y}(0,1)+(0-0.5)(0)p_{X,Y}(0,0)=$$
$$\frac{1}{2}\cdot\frac{3}{8}+0-\frac{1}{2}\cdot \frac{3}{8}+0=0$$
docnet said:
Homework Statement:: .
Relevant Equations:: .
View attachment 293161(a)
That's not what I get. If ##X = 1##, then we toss the unbiased coin (coin 1) again.
yes! the problem I solved isn't same as the problem in the prompt :(
but don't worry, i think i know what the problem is asking, and how to solve it
OK so here's what I have
(a)
$$P_{X,Y}(1,1)=\frac{1}{2}\frac{1}{2}=\frac{1}{4}$$
$$P_{X,Y}(1,0)=\frac{1}{2}\frac{1}{2}=\frac{1}{4}$$
$$P_{X,Y}(0,1)=\frac{1}{2}\frac{3}{4}=\frac{3}{8}$$
$$P_{X,Y}(1,1)=\frac{1}{2}\frac{1}{4}=\frac{1}{8}$$(b)
$$P_X(1)=\frac{1}{4}+\frac{1}{4}=\frac{1}{2}$$
$$P_X(0)=\frac{3}{8}+\frac{1}{8}=\frac{1}{2}$$
$$P_Y(1)=\frac{3}{8}+\frac{1}{4}=\frac{5}{8}$$
$$P_Y(0)=\frac{1}{8}+\frac{1}{4}=\frac{3}{8}$$
(c)
$$E(Y)=\frac{5}{8}+0\cdot \frac{3}{8}=\frac{5}{8}$$
(d)
$$E((X-.5)\times Y)=(\frac{1}{2}\frac{1}{2}-\frac{1}{2}\frac{1}{2})\frac{5}{8}=0$$
It looks right apart from the answer to d). Note that in general ##E(XY) \neq E(X)E(Y)##. (Another simple but erroneous calculation on your part!) But, in general, ##E(X + Y) = E(X) + E(Y)##. That gives you two ways to do part d): go through the four options, or use the expected value of a sum.
@PeroK thank you :) is this what you mean?
using the formula:
$$E((X-.5)Y)=\frac{1}{8}-\frac{3}{16}=-\frac{1}{16}$$ 😒using linearity and the definition of covariance:
$$E((X-.5)Y)=E(XY)-\frac{5}{16}$$
$$E(XY)=cov(X,Y)+E(X)E(Y)=-\frac{1}{16}+\frac{5}{16}$$
$$E((X-.5) Y)=-\frac{1}{16}$$ 😇
Likes PeroK
Yes, it's good to see you do it both ways and get the same answer!
Note: the quick and valid way to get ##E(XY)## is to note that ##XY## is only non-zero when ##X = Y = 1##, which happens with probability ##1/4##. Hence ##E(XY) = \frac 1 4##.
  • Love
Likes docnet
