281Oleg
- 13
- 0
The kaleidoscope of periodic tables.affinity (eV)
In my last work I show secondary periodicity on this property for s-elements on the example of the data on electron affinity. In the same place, on the example of d-elements other logic of the tableis visible, - not periodicity but cyclicity.
Some properties are cyclic and not correspond to the periodic table.
I offer to your attention http://www.genevo.org/H.htm
It is visible on the schedule that on the property of electron affinity s-elements behave variously before p and d-elements . Before р - elements electron affinity grows, before d-falls.
Even on this property it is possible to speak about available laws which are not clear yet.
That means that affinity before new family "knows" what family will be farther.
About the same scheme of cyclicity it is possible to make for all other families.
Except of cyclicity of orbitals 3 2 3 2 for d-elements, there exist such cyclicities – “reversed”, "regressive" and "progressive". For their construction it is necessary to number orbitals.
But also other cyclicity exists which is connected with growth of number of electrons in atom. When electron is filling , the cyclicity is defined by occurrence of every new electron instead of orbital for two electrons.
Different types of cyclicity connected with representing of different properties of atom. http://www.genevo.org/E.htm
Don't you want to make some comments? I thought I made a good table.
Specific properties are inherent in each family of chemical elements.
When constructing the table of periodic specific properties of one element’s family, other families has this property partly (comparably) periodical or as an absent one (is not shown). A parity of families with expressed properties or partly expressed properties or not expressed properties is natural.
Specific properties of element’s families determine the form of the table. All tables are naturally connected.
The continuation of the table of overjumpings of electrons http://www.genevo.org/OD.gif - the table of electrochemical series (fragment). http://www.genevo.org/E.htm
In this periodic table an electrochemical series of potentials of 3d-elements and 5d-elements is very similar. It is shown on the graph. http://www.genevo.org/Ef1.gif And a series of electrochemical potentials of 4d-elements is differing from series of potentials of 3d-elements and 5d-elements. If to turn this series and increase on-1 you see that areas of maxima and minima of this series will coincide with the areas of maxima and minima of electrochemical series of potentials of 3d-elements and 5d-elements. Graph http://www.genevo.org/Ef2.gif
