The magnetic field of a spinning spherical shell of uniform charge
The discussion centers on a problem from Griffiths' "Introduction to Electrodynamics" regarding the magnetic force of attraction between the hemispheres of a spinning charged spherical shell. A participant attempts to calculate the magnetic field at the southern tip using the Biot-Savart law but expresses uncertainty about their results. They derive a formula for the magnetic field but receive feedback indicating errors in their calculations, particularly in unit consistency. Another contributor suggests reviewing example 5.11 in the textbook, which may provide helpful context for solving the problem. The conversation highlights the complexity of the problem and the importance of verifying calculations in magnetostatics.
Hegoeth
In chapter 5, magnetostatics, of Griffiths' Introduction to Electrodynamics (third edition), there's a problem in the back of the chapter that asks you to calculate the force of attraction between the northern and southern hemispheres of a spinning charged spherical shell.
The problem in its exact words:
Problem 5.42: Calculate the magnetic force of attraction between the northern and southern hemispheres of a spinning charged spherical shell.
Well, we haven't gotten so far in our class that I can actually do this. But I'm reviewing for the test, so I figured there was at least some part of the problem that I could do. I decided to calculate the magnetic force at the southern tip P. Seeing as this isn't the problem, I don't know if my answer is correct. Here's what I did:
I used the Biot-Savart law to do so. I let the distance from P to the point of current dI be r, the height (which goes from 0 to 2R) be z, and the distance from z to dI be a. Radius = R.
I used these values to work out a formula for r, namely r^2= z^2 + (2Rz)^2. My current I = σω(2Rz - z^2)^(1/2) (though I'm thinking it should be line charge λ). The diameter is equal to 2∏(2Rz - z^2)^(1/2)
My Biot savart law has me integrate I/r^2 cos∅ which turns into:
B = σμω/2 * Integral[(z*diameter)/(r^(3/2))]​
Resulting in the magnetic field B equal to μσω/3 (which seems unlikely to me.)
If formatting this or scanning my work to this post would motivate someone to actually verify my answer, then I'll do that... just let me know.
It's brave of you to have a go at this. I'm afraid I haven't gone right through your attempt, but I've spotted a couple of things near the beginning.
Neither of these can be right, because the units don't match. Always check units!
In the first equation the units of the first two terms are m2, but the unit of (2Rz)^2 is m4. For what it's worth, I got r^2 = 2Rz.
The right hand side of the second equation has the units Am-1. What you're calling I is the current per unit arc length of a line of longitude as the sphere rotates.
Hope this is of some help.
Oh my, I'll have to go over it again at some point today. I'll report back if I make any more progress. Thanks!
I thought the original problem you posted looked hard, and a brief search of the internet using "Griffiths spinning charged hemispheres question" confirmed that it was! Apparently – I don't possesses Griffiths – you should first study example 5.11. This uses vector potential, A, though in my limited experience many problems that can most neatly be done using A can be done more laboriously using the ordinary field vector, B.
Good luck!
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
