What is the role of dx in mathematical and scientific calculations?
  • B
  • Thread starter anonymous24
  • Tags
    Dx
In summary: V as an actual value, but I'm not too familiar with them.)In summary, the conversation discusses the meaning of dx in the context of physics and mathematics. It is agreed that dx represents a small change in x and it can be treated as an infinitesimal value. The concept of differentials is also mentioned, with the definition being a function at a specific point. The conversation also touches on the use of infinitesimal quantities in math and physics, and the historical development of notations for differentiation.
anonymous24
Hello,
I am slightly confused about the actual meaning of dx. Because I read in a physics textbook, they say something along this line:
"We divide this region into spherical shells of radius r, surface area 4pr 2, thickness dr, and volume dV = 4pr^2 dr."
I don't understand how can we represent dV like this, like it's a small bit of the total V. However, we learned in mathematics dx represent a small "change" in x. I am not sure whether I should treat dx as an infinite small x or infinite small change in x. Thank you for answering my question in advance!
Likes Stavros Kiri
Infinitely small change and infinitely small are the same in this context.
Thanks for the reply, but why is that? Could you also please give an example where it won't be the same? thank you
Formally, ##dV = 4pr^2 dr##
means
##\frac{dV}{dr} = 4pr^2##
In standard math, a differential only makes any sense if you can rearrange the equation such that one differential sits on top of another. You can treat the differentials as objects that you can divide, but the real definition comes from the epsilon delta definition of the derivative.
(There are some non-standard analysis methods that treats dV as an actual value, but I'm not too familiar with them.)
Likes Stavros Kiri and anonymous24
Treat it as a little chunk of x. An infinitesimal one. Or in your words, a small change in x.
I hate to say this, but even though a lot of math guys out there try to pretend they're really angry because you're using infinitesimal quantities, you will get pretty far in your math education if you use these infinitesimal quantities. Their anger is kind of bogus too, since I've seen pure math guys use this concept as well. It's just convenient and makes a ton of sense. Also, if you're in physics, you absolutely need this concept since so many equations rely on it.
Likes Stavros Kiri
Thanks for the reply, so do you mean a small change in x and a small chunk of x is the samething? that's the thing the confuses me.
I don't think you should spent many thoughts on this answer. The easiest way is in my opinion to look at where it comes from:
$$\frac{dV}{dr} = \lim_{\Delta \, r \rightarrow 0} \frac{\Delta \,V}{\Delta \, r} \ \ \ \ \ \ (1)$$
so in general it's a tiny difference. But a closer look shows us, although ##\Delta \,r## might be a tiny difference in the denominator, it can still result in a big one in the nominator ##\Delta \, V##, which makes it context sensitive. I think one should keep this in mind, when dealing with ##dr## as something small. I see @mathman's remark in post #2 as the short form to say: Whether we define it as in ##(1)## or by
$$\frac{dV}{dr} = \lim_{h \rightarrow 0} \frac{V(r+h) - V(r)}{h} \ \ \ \ \ \ (2)$$
doesn't make a difference. In the first case ##dr \approx \Delta \, r## is an infinitesimal small change in ##r## and in the second it is an infinitesimal small piece of ##r##, so ##dr \approx h##.
As these notations developed, it wasn't clear at the time, which way would be the best to handle them, or even what exactly they mean. So a brief look into history might also be very enlightening. A start could be the corresponding Wikipedia entries:
https://en.wikipedia.org/wiki/Leibniz's_notation
https://en.wikipedia.org/wiki/Notation_for_differentiation#Lagrange.27s_notation
https://en.wikipedia.org/wiki/Hyperreal_number
Likes malawi_glenn, Logical Dog and Stavros Kiri
The Differential (of a function f=f(x)) in rigorous mathematics is defined as a function, e.g. at a point x0, df|x0(h) = {limx→x0[f(x)-f(x0)]/(x-x0)}•h = f'(x0)•h
By varying h small, you basically get the same results and idea/concept as in physics, or non-rigorous mathematics and/or mathematical physics. I hope that helps. (+ it interprets and unifies some of the above replies* and approaches ...)
*most of them unique, correct and useful in their own ways and perspectives ! ...
P.S. (last edit): CAUTION! (for all) : In trying to understand this post, please be careful [for all] not to be confused ! ... (but it is/(can be) very fruitful and useful if you do in fact understand it ...)
[e.g. you might ask yourself "why/(how come) differential [is] a function? etc." ...]
But the definition works, in [/and covers] all cases ... . Just do the simple math, e.g. f'(x) = df(x)/dx, and plug it in in the definition, to interpret/justify everything, even the symbol/notation df/dx ... . Then think of what a function actually is and does (e.g. allows you to vary the variance h, and make it as small as you want, etc.), and let your mind free ... . The concept tacitly behind it: continuity (of a function, the Reals (i.e. Real numbers set), etc.), ... etc. .
It's all very deep, it works, plus a good intelectual exercise too! [May be rigorous mathematicians aren't useless after all ...] And thanks to the OP (anonymous24), for bringing up the issue.
Likes Logical Dog
You have a [good] point (especially for physicists to pay attention and caution) but not quite true (see previous post above).
Also regarding:
That's the idea, but ... as a function ... not "an actual value" ... (unless you take the value of the differential function df(h) at h=h0 ...)
anonymous24 said:
Thanks for the reply, so do you mean a small change in x and a small chunk of x is the something? that's the thing the confuses me.
I think I see your confusion. You might want to think of it this way:
If you are integrating, then a little chunk of x is a better way to think of it. For example, say you have a density function ##\rho(x)##, where ##x## is the coordinate along some rope or something. The mass on a little piece of rope is ##\rho(x)dx## where clearly, I have assumed ##dx## is a little chunk of rope.
If you are differentiating, then thinking of ##dx## as a change in ##x## might be better. For example, say ##x## is the quantity of something, and ##F## is some function of ##x##. Then you could think of ##\frac{dF}{dx}## as how much F changes if you input a little change in x.
But this is very wishy washy. Now that I think of it, sometimes you think of ##dx## as a little chunk of something and sometimes as a small change in ##x##. I guess it depends on the problem. I think your confusion in this problem might disappear if you do more concrete problems and try to put some meaning into the differential.
Likes Stavros Kiri
Lol (about the math guys etc.), a bit sarcastic, but mostly or partially true enough!
However see post #9 above ..., it unifies things (but careful [for all] not to be confused ! ...), ...etc.
Likes davidbenari
Dx is an infinite small change in x
This is a vague statement ...
[for example, how do you define 'infinite small'? (or better: 'infinitely small') ... . Limit? Or function with a small variance range? ... etc.]
An infinite number of dx that is infinitely small can fill up the segment length of 1.
Likes Stavros Kiri
That's 01dx = 1, so true enough! ...
Two more remarks:
1.
Not quite true. We have:
Δx = x-x0 . By taking Δx as small as we want (i.e. in the limit), x0 can still be anything ... . In the h notation though, i.e. x = x0 + Δx = x0+h, the h variable is the one that gets "infinitely small" ... [and x, x0 can still be anything (that meet that small difference) ].
Therefore, since Δx = h, that's the variable that gets infinitely small, not x or x0. {See also fresh_42 ' s post #8 above}
And in that sense, dx is a[n infinitely] small change in x, or small chunk of x, but also a small h ...
So
is good enough.
2. The effect on a (real) function is briefly as follows:
df(x) = f'(x)dx [where f'(x) = df(x)/dx]
So if dx gets "very small", and the derivative f'(x) exists and is finite, then also df(x) gets very small ...
In essence that expresses the known theorem in Calculus that sais that "A differentiable function is necessarilly continuous" (but not vice versa [i.e. not all continuous functions are differentiable] ...).
Also these are relevant to:
I don't think ##dx## ever means infinitely small ##x##. ##dx## always represents an infinitely small change in the value of ##x##. I don't think infinitely small ##x## has any meaning. You can only change ##x## by an infinitely small amount. In calculus, ##dx## is assumed to be smaller than any other change in ##x##, such that if an interval has a length ##dx##, then even a function, whose value continuously changes can be assumed to be constant over that interval. Let our continuously varying function be ##x^2##. At ##x=2##, it has a value 4. Even when we change ##x## by a very small, but finite amount, 0.001, then ##2.001^2## comes out to be 4.004001. You see that ##x^2## always changes, no matter how small change in ##x## we bring because it is continuously varying, i.e. it always has a non-constant derivative. ##dx## is assumed to be a change so small, smaller than any other change, that even the value of continuously varying functions remains virtually constant when we change ##x## by that amount. So, the change in the value of ##f(x)=x^2## when ##x## changes from ##2## to ##2+dx## is so small that it can be assumed to be the same at ##x=2## and ##x=2+dx##.
Let's try to find surface area of a cylinder. It can be assumed to be made of an infinite number of circles or circumference ##2\pi r## distributed over a height ##h## each of breadth ##dx##. The surface area contributed by each of these circles is ##2\pi rdx##. So, the surface area must be the 'sum' of these infinite number of circumferences, which is ##2\pi rdx+2\pi rdx+2\pi rdx+...## upto ##h## terms##=2\pi rh##. Let's try to find the volume of a sphere in a similar way. The sphere can be assumed to be made up of an infinite no. of spherical shells each of 'breadth' ##dx##. Note that the circumferences of all the circles making up the cylinder were constant but in this case the surface areas of all these shells are not the same. If a shell is at a distance ##x## from the center of the sphere, then its surface area is ##4\pi x^2##. Since, ##dx## is infinitely small, so this surface area can be assumed to be constant over this breadth. So, the volume contributed by each spherical shell is ##dV=4\pi x^2dx##. Now, the mathematical tool of adding all these non-constant small volume contributions is integration, which gives ##V=\int_0^R4\pi x^2dx##
Likes Stavros Kiri
Kumar8434 said:
I don't think dx ever means infinitely small x. dx always represents an infinitely small change in the value of x.
But rather in the h variable it makes sense (Δx=h can get infinitely small ... [Δx = x-x0 = h can be thought of as a change of variable, for a particular point x0] ).
Kumar8434 said:
I don't think infinitely small x has any meaning. You can only change x by an infinitely small amount.
x is the variable of a real function here. E.g. it can be x=0 or x→0 ...
Kumar8434 said:
In calculus, dx is assumed to be smaller than any other change in x, such that if an interval has a length dx, then even a function, whose value continuously changes can be assumed to be constant over that interval.
We sometimes do that , but this is not rigorous calculus (may be mathematical methods in physics, one kind - nothing wrong with that, perhaps). It can get misleading (see ahead). The rigorous concepts behind those things (that we are all trying to describe here) are the notions of limit and continuity (with the regular rigorous ε-δ definition ...) and definitions of derivative (as a limit), differential (see post #9 above) and integral (with the use of Sums and sequences, Sup and Inf and the sequence of partitions/sum/limit ...).
Other than that we are talking about approximations and approximative concepts, which of course can be very useful and enlightening (especially in Physics), but sometimes can be misleading.
For example
... not quite true. That is actually true only for dx=0 or in the limit (dx or h → 0). In fact f(x+dx) ≅ f(x) + f'(x)dx, or more accurately, if the binomial expansion exists:
f(x+dx) = f(x) + (1/1!)f'(x)dx + (1/2!)f''(x)(dx)2 + (1/3!)f'''(x)(dx)3 + ... ...
So what you say is actually true only as approximation (and in fact 0th order, not even 1st order approximation) or in the limit (dx or h → 0). But we use that in proofs, as intermediate step sometimes, to avoid pedantic and tedious ε, δ definitions or nasty partitions sums and limits in the integrals etc.
Thus your comments and post are useful, but I just thought I would make these clarifications.
Stavros Kiri said:
But rather in the h variable it makes sense (Δx=h can get infinitely small ... [Δx = x-x0 = h can be thought of as a change of variable, for a particular point x0] ).x is the variable of a real function here. E.g. it can be x=0 or x→0 ...We sometimes do that , but this is not rigorous calculus (may be mathematical methods in physics, one kind - nothing wrong with that, perhaps). It can get misleading (see ahead). The rigorous concepts behind those things (that we are all trying to describe here) are the notions of limit and continuity (with the regular rigorous ε-δ definition ...) and definitions of derivative (as a limit), differential (see post #9 above) and integral (with the use of Sums and sequences, Sup and Inf and the sequence of partitions/sum/limit ...).
For example
Yeah, I should've said that the derivative of the function can be assumed to be constant when ##x## changes by an amount ##dx##. In the sphere example, the volume of the sphere is continuously changing by a rate ##4\pi x^2##. So, in the graph of the volume function of a sphere, we can assume the part of the graph between ##x## and ##x+dx## to be a straight line of slope ##4\pi x^2## so that the small change in volume ##dV## contributed by this part can be obtained by directly multiplying the change in ##x## ,i.e. ##dx## with the constant rate of change, i.e. ##4\pi x^2##. So, the function is assumed to be changed by a small amount ##dV##, and this ##dV## is obtained by assuming that the graph of the function is a straight line between ##x## and ##x+dx## so that its derivative remains constant over that part.
Sorry, I got confused by the 'adding the rectangles' explanation I read in my book. So, I thought that the two sides of the rectangle parallel to the ##y-axis## should be equal and hence the function is assumed to remain constant. But, now I think, if those two sides of rectangle differ by a small amount ##dy##, then they're no longer rectangles, then shouldn't we be adding the trapeziums instead?
Kumar8434 said:
Sorry, I got confused by the 'adding the rectangles' explanation I read in my book. So, I thought that the two sides of the rectangle parallel to the y−axisy−axisy-axis should be equal and hence the function is assumed to remain constant. But, now I think, if those two sides of rectangle differ by a small amount dydydy, then they're no longer rectangles, then shouldn't we be adding the trapeziums instead?
You can do with trapeziums too, but in the limit the result is the same (and in between the inf, sup limits of the Riemann sums, in rigorous calculus ...). These dx ideas etc. are already in the notion of limit etc., as mentioned before.
No. I just figured out my mistake. We add up the rectangles when working with the graph of ##f'(x)## to calculate change in ##f(x)## by adding up the areas. Since ##f'(x)## is assumed to be unchanged over the interval of length ##dx##, so the graph of ##f'(x)## can be considered parallel to the ##x-axis## and hence the two sides of our rectangle are of the same length. We do this when working with the graph of ##f'(x)## to find change in the value of ##f(x)##.
If instead the graph of ##f(x)## is used to calculate change in the value of ##f(x)##. In this case, the part of the graph in the interval of length ##dx## can also be assumed to be a straight line but this time, this line is not necessarily parallel to the ##x-axis##. In fact, this straight line has a slope ##f'(x)##. So, in this case, to calculate change in ##f(x)##, we can assume the graph to be touched by an infinite number of triangles instead, each of base length ##dx##, so that the small change in ##f(x)## can be obtained by multiplying ##\tan{\theta}## of each triangle, i.e. ##f'(x)## with the base length, ##dx##, which gives ##dy=f'(x)dx##. So, there's no question of adding trapeziums.
Interestingly, if we assume the graph of ##f(x)## is to be touched by an infinite no. of triangles, then we can also obtained the formula for the length of the graph. Because the value of ##\tan{\theta}## for each of these triangles is ##f'(x)##, so the value of ##\sec{\theta}## is ##\sqrt{1+{(f'(x))}^2}##. So, the infinitely small contribution to the length of the graph can be obtained by the length of hypotenuse of that triangle, which is ##\sec{\theta}*dx=\sqrt{1+(f'(x))^2}dx##. Integrating this gives the length of the graph.
anonymous24 said:
Hello,
Suppose a car was initially at ##x=0## at ##t=0## and that it is traveling such that the distance is travels in any time ##t## is ##t^2##. If I asked you where was the car at ##t=3##, that shouldn't be much problem for you. You can easily say that the car was at ##x=3^2=9m##. Now, what if I asked you about what was the speed of the car exactly at ##t=3##? Maybe, you could calculate the small distance it traveled between ##3s## ##3.1s## and divide that by the time taken, i.e. ##0.1s##. This gives you ##3.1^2-3^2## divided by 0.1 which is equal to 6.1. You can assume that the speed of the car remained unchanged in these 0.1s and answer tell me that the speed of the car at ##t=3s## was 6.1m/s. The interval that you picked here was of ##0.1s##. But I may say that 3.01s is closer to 3s than 3.1 second is close to 3s. So, the average speed between 3s and 3.01s should give a better estimate of what was the speed of the car exactly when the time was 3s. Now, you calculate the average speed to be ##\frac{3.01^2-3^2}{0.01}## which gives you the speed to be 6.01m/s. You can argue that the speed of the car in this small interval of 0.01s remained unchanged and hence, when the time was exactly t=3s, the speed of the car was 6.01m/s. But, what if the speed of the car changed between t=3s and t=3.01s? Now, you have to choose a smaller interval to get a better estimate of what exactly the speed was at ##x=3s##. The derivative does this work for you and calculates the speed of the car at ##x=3s## by considering the smallest change in time possible, i.e. ##dt##. I think now this expression makes sense:
$$lim_{dt\rightarrow 0} \frac{(3+dt)^2-3^2}{dt}$$
The numerator gives you the small distance that the car moves when the time changes from ##3## to ##3+dt##. The denominator is to divide that change in distance by the small change in time, ##dt##. And the ##lim_{dt\rightarrow 0}## ensures that you're using the smallest change in time possible. This limit evaluates to 6m/s which is the speed of the car exactly at ##x=3s##.
anonymous24 said:
Hello,
Suppose a car was initially at #x=0# at #t=0# and that it is traveling such that the distance is travels in any time ##t## is ##t^2##. If I asked you where was the car at ##t=3##, that shouldn't be much problem for you. You can easily say that the car was at ##x=3^2=9m##. Now, what if I asked you about what was the speed of the car exactly at ##t=3##? Maybe, you could calculate the small distance it traveled between ##3s## ##3.1s## and divide that by the time taken, i.e. ##0.1s##. This gives you ##3.1^2-3^2## divided by 0.1 which is equal to 6.1. You can assume that the speed of the car remained unchanged in these 0.1s and answer tell me that the speed of the car at ##t=3s## was 6.1m/s. The interval that you picked here was of ##0.1s##. But I may say that 3.01s is closer to 3s than 3.1 second is close to 3s. So, the average speed between 3s and 3.01s should give a better estimate of what was the speed of the car exactly when the time was 3s. Now, you calculate the average speed to be ##\frac{3.01^2-3^2}{0.01}## which gives you the speed to be 6.01m/s. You can argue that the speed of the car in this small interval of 0.01s remained unchanged and hence, when the time was exactly t=3s, the speed of the car was 6.01m/s. But, what if the speed of the car changed between t=3s and t=3.01s? Now, you have to choose a smaller interval to get a better estimate of what exactly the speed was at ##x=3s##. The derivative does this work for you and calculates the speed of the car at ##x=3s## by considering the smallest change in time possible, i.e. ##dt##. I think now this expression makes sense:
$$\lim_{dt \to 0} \frac{(3+dt)^2 -3^2}{dt}$$
The numerator gives you the small distance that the car moves when the time changes from ##3## to ##3+dt##. The denominator is to divide that change in distance by the small change in time, ##dt##. And the ##\lim_{dt \to 0}## ensures that you're using the smallest change in time possible. This limit evaluates to 6m/s which is the speed of the car exactly at ##x=3s##.
Kumar8434 said:
No. I just figured out my mistake. We add up ...
... Integrating this gives the length of the graph.
Acknowledged. If you do the appropriate sums and limits carefully they all have to agree, as you verified in that case.
A number of replies are off-topic here, as the original question is "what is dx?" The OP hasn't been around since Feb. 8, so presumably his question has been answered.
Hello, @fresh_42
You wrote that "In the first case ##dr \approx \Delta \, r## is an infinitesimal small change in ##r## and in the second it is an infinitesimal small piece of ##r##, so ##dr \approx h##."
I have difficulty understanding this topic.
How is it possible that ##dr \approx \Delta \, r## ?
dr is infinitesimal, but ## \Delta \, r## is real number. What do you mean?
Thanks!
Likes PeroK
Mike_bb said:
Hello, fresh_42
Thanks!
That's why it is not equal "##=##" and only approximately "##\approx##". Both are used as small amounts since we consider ##\Delta r ## for ##r\to 0## and they point in the same direction. The problem is: What does ##dr## even mean?
It is actually used in several different contexts: a notation for a limit, an infinitesimal quantity, a mark to note an integration variable, a mark to note the variable of differentiation, a Pfaffian form, a basis vector in tangent space, and possibly a few more. Of course, it is always the same thing in the end but looking at it from so different perspectives that this "same" becomes almost unrecognizable.
I understood this thread as ##dr = \lim_{r\to 0}\Delta r.## So ##dr \approx \Delta r## if only ##r## is small enough, and these are the only values we are interested in.
Likes Mike_bb
In Mathematical Logic ##dx## denotes an infinitesimal number. An infinitesimal number is an hyper-real number that is not contained in the set ##\mathbb{R}##. We can define the infinitesimal number ##dx## by the relation ## dx < \frac{1}{n} ## for each ##n\in \mathbb{N}##. We can call this property ##P_{n}## for every ##n\in\mathbb{N}##. Now by the compactness theorem (K.Gödel, 1930) there exists an extended model for ##\mathbb{R}## denoted by ##^*\mathbb{R}## that contains the infinitesimals ##dx, dy, ...##. Taking the limit operation is like to take the standard part of these numbers: ## \frac{dy}{dx} = \lim_{\Delta x \rightarrow 0}\frac{\Delta y}{\Delta x}## that is ##\frac{dy}{dx} = St\left(\frac{\Delta y}{\Delta x}\right)##, note that for an infinitesimal number ##St(dx)=0##, so for example if ## f(x)=x^2## then ##\frac{dy}{dx} = St\left(\frac{\Delta y}{\Delta x}\right)= St\left(\frac{(x+dx)^2-x^2}{x+dx-x}\right) = St\left(\frac{x^2+2xdx+dx^2-x^2}{dx}\right)## that is ##= St\left(2x +dx\right)=2x## (see Non-standard analysis by Robinson).
Ssnow
Likes Delta2
You can also see dx as a 1-form, so that fdx is a 1-form to be integrated over a 1-manifold (a,b)
or as one of the elements of the dual bases to (0,1), (1,0), i.e., dx(0,1) =0 ; dx(1,0)=0 , dy(1,0)=0 dy(0,1)=1,
in this sense, it acts as a projection map .
Related to What is the role of dx in mathematical and scientific calculations?
1. What is dx in mathematical and scientific calculations?
dx is a mathematical notation used to represent an infinitesimally small change in the independent variable in a function. It is commonly used in calculus to indicate a small change in the value of x.
2. Why is dx important in mathematical and scientific calculations?
Dx plays a crucial role in mathematical and scientific calculations because it allows us to break down complex functions into smaller, more manageable parts. It also allows us to calculate derivatives and integrals, which are essential in many areas of science and engineering.
3. How is dx used in differentiation and integration?
In differentiation, dx represents the change in the independent variable x, which is used to calculate the slope of a curve at a specific point. In integration, dx is used to represent an infinitesimally small width of a rectangle, which is then multiplied by the value of the function to find the area under the curve.
4. Can dx be used in other areas of science besides mathematics?
Yes, dx can also be used in physics, engineering, and other fields of science. In physics, it is used to calculate the rate of change of a physical quantity, such as velocity or acceleration. In engineering, it is used to find the optimal values of variables in a system.
5. Is it possible to perform calculations without using dx?
Yes, it is possible to perform calculations without using dx. However, dx is a convenient notation that simplifies many mathematical and scientific calculations, making them more efficient and accurate. It also allows us to solve more complex problems that would be difficult to solve without it.
  • Calculus
  • Calculus
