I The Method of Images (Electromagnetism)
Grounding a conductor means setting its electric potential to zero, which simplifies calculations in the method of images. While an infinite conducting plane is often used for convenience, finite planes can also apply the method, though with more complex mathematics. Grounding allows the plane to accept charges without altering its potential, establishing a fixed reference point. The choice of zero potential is arbitrary, as only potential differences are physically significant. Understanding these concepts clarifies the application of the method of images in electromagnetism.
sinus
TL;DR Summary
What is the effect of the plane that being grounded make its electric potential become zero?
Can anyone explain to me why grounded means zero electric potential. I confuse what's the relation between infinite ground conducting plane and its electric potential (the method of images).
I have a several question:
1. Why the conductor plane must be infinite, while in reality there's no such one.
2. Why the electric potential must be zero to using this method?
2. If the plane isn't be grounded, does its electric potential not zero? What's exactly that making the potential in the plane zero when we grounded it? How ?
As far as I know that the electron easily run into the ground, does it mean the plane become positive charge?
It's arbitrary what you define to be zero because only potential differences matter. If there is a ground connection then that's usually defined to be zero.
There is too much context missing to answer your individual questions.
1. Conducting plates don't have to be infinite in general.
2. Which method?
Likes sinus and Dale
Because it makes the calculation easier. A large but finite plane would give approximately the same answer, but with more mathematical effort required.
Because it makes the calculation easier. You can set it to any potential you like, but setting it to zero is convenient.
Grounding allows the plane to accept charge without changing potential. So grounding produces a structure with a fixed potential. It is merely a mathematical convenience to set that fixed potential to zero.
It is just an arbitrary choice. The value of potential is not physical. Only potential differences are physically meaningful.
No. As I said above, grounding makes it so that the plane has a fixed potential which does not change as charges are added or removed.
Likes sinus and hutchphd
2. Which method?
Thank you for your reply sir, I finally understand the method of images. Sorry for long tome didn't respond. For your feedback,number 2: the method that I meant is the method of images, like why using that solutions method (thank god, now I know the reason)
For number 1, I don't follow. So for a finite conducting planes the method of images is still apply?
Thank you so much for your explanation sir, it really helpful for me :)
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
