The movement of a package on a conveyor belt
  • Thread starter Thread starter Losmonkeys17
    Movement
The discussion focuses on the calculation of work done on a package moving on a conveyor belt, specifically using the equation W = -1/2*m*vi^2. Participants clarify that W represents the work done, while vi denotes the initial velocity of the package. There are questions about the reference frame used for computing work, highlighting the importance of context in physics problems. The conversation emphasizes the need to specify the reference frame for accurate calculations. Understanding these concepts is crucial for correctly applying the work-energy principle in this scenario.
Losmonkeys17
A package is dropped on a horizontal conveyor belt. The mass of the package is m = 0.563 kg, the speed of the conveyor belt is v = 0.947 m/s, and the coefficient of kinetic friction between the package and the belt is μk = 0.253.
a) How long does it take for the package to stop sliding on the belt?
0.382 s
You are correct.
b) What is the package’s displacement during this time?
0.181 m
You are correct.
c) What is the energy dissipated by friction?
0.252 J
You are correct.
d) What is the total work done by the conveyor belt?
W=-1/2*m*vi^2, W = Fd - fmgd
I have tried doing W=-1/2*m*vi^2 and total work = W + friction work
Losmonkeys17 said:
W=-1/2*m*vi^2
In that equation, how exactly is W defined? And doesn’t vi represent initial velocity?
In what reference frame are you computing the work done? In what reference frame does the task want the work done to be computed?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
