B The resistance of an ohmic conductor
The resistance of an ohmic conductor increases with length due to more collisions experienced by electrons. Decreasing the cross-sectional area also raises resistance because it reduces the current (I), as defined by the equation R = V/I. This relationship indicates that a smaller area results in fewer pathways for electrons, leading to higher resistance. The discussion compares adding length to a wire with adding resistors in series, reinforcing the concept of resistance. Understanding these principles clarifies the behavior of conductors in electrical circuits.
Viona
I know that the resistance of an ohmic conductor increases with length because the electrons going through the conductor must undergo more collisions in a longer conductor. But why decreasing the cross-sectional area of the conductor also increases the resistance of a conductor?
Think of increasing the area as having many conductors in parallel. Decreasing is the opposite.
Likes Viona, vanhees71, DaveE and 1 other person
I am not sure that your intuitive model, according to which you conclude more resistance means more collisions is entirely correct.
Formally resistance is defined as ##R=\frac{V}{I}##. Decreasing the cross sectional area decreases I and that's why R is increasing. (it is ##I=nSve## where ##S## the cross sectional area, ##n## the density of free electrons, ##v## the average drift velocity and ##e## the charge of electron.)
If you like an intuitive model, adding length to a resistive wire is the same as adding resistors in series.
Likes Viona and vanhees71
Thank you, that was helpful and nice.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
