B The synchronization of clocks and the relativity of motion
  • #51
AlMetis said:
reciprocal kinematics as the principle of relativity claims
Where are you getting this "reciprocal kinematics" as a requirement of the principle of relativity? What reference is this from? Is it from Einstein's paper? If so, please give a specific quote.
Likes Dale
  • #52
AlMetis said:
The laws are not shown to differ, the observations are shown to differ,
AlMetis said:
There is no change in the laws between diagrams, as far as I know.
Then it does not violate the principle of relativity.
The principle of relativity claims only that the laws of physics are the same in different frames, not that what you are describing as observations are different. Btw, I would not describe those as observations. I would reserve the term "observation" for the actual measured result on some specified experimental measurement device. That is always necessarily an invariant quantity.
AlMetis said:
they are not reciprocal kinematics as the principle of relativity claims.
This is a big misrepresentation of what relativity claims. You need to rescind this erroneous statement; misinformation is not tolerated here on PF.
  • #53
AlMetis said:
As you cannot measure the one way time of flight directly, you must deduce it from kinematic law as Einstein did in the equations above #29.
That's irrelevant. The definition of a standard inertial coordinate-system contains a time-coordinate, that is based on the definition of time as the reading of a standardized clock and on Einstein's definition, that the one-way speed is isotropic.
The relativity of simultaneity between such coordinate systems is a physical effect. It would not exist, if time were absolute.
  • Skeptical
Likes Dale
  • #54
Dale said:
This is a misrepresentation of what relativity claims. You need to rescind this claim, misinformation is not tolerated here on PF.
I will rescind this claim.
Can you please explain why?
As I understand it, reciprocal kinematics follow from the principle of relativity of motion between inertial frames. If observations of kinematics between inertial frames are not reciprocal, those that fail reciprocity are distinguishing one frame from another, thus (uniform) motion is no longer a relative measure as the principle claims.
What part of this is incorrect?
Likes Dale
  • #55
Sagittarius A-Star said:
That is irrelevant, because B is not located in the middle between the locations of the reflection-events, with reference to the rest-frame of the ground.
B is at the mid point between the mirrors at the time of the flash, which is the time that the distance to the mirrors is relevant.
  • Skeptical
Likes Sagittarius A-Star
  • #56
Why?
  • #57
Why?
Because we are measuring from the flash to the mirrors, and the flash is at the midpoint at time =0
  • Skeptical
  • #58
What is the related role of observer B?
  • #59
As I asked before, where are you getting this from? Please give a reference.
  • #60
The only thing that the principle of relativity states is that the laws of physics are the same in any reference frame.
What you call reciprocal kinematics does not follow from the principle of relativity. I have already explained why, but I will do so again in more depth.
The laws of physics are expressed as differential equations, or (even better) as a Lagrangian or Hamiltonian. When you solve a differential equation, by itself, you do not get a single solution. Instead, you get a family of solutions. In order to get a single solution you must also supply what is called boundary conditions or initial conditions. Additionally, if the differential equation itself has some parameters, you will need to specify those parameters too.
For example, for a projectile the law of physics is:
##m \ddot z = -mg## or (even better) ##\mathcal L = \frac{1}{2}m \dot z^2 - mgz##.
If you solve this (in either form) you get the equation of motion:
##z(t)=\frac{1}{2} g t^2 + v_0 t + z_0## where ##v_0## and ##z_0## are the initial conditions.
Those initial conditions do not come from the law of physics, and any initial conditions satisfy the equation of motion and therefore the law of physics.
What you are calling the "kinematics" is the equation of motion, not the law of physics. So it depends not only on the law of physics but also the boundary conditions. The principle of relativity requires that the law of physics be the same in both frames, but does not require that the boundary conditions be the same. In you example, the boundary conditions are different in the different frames, so the different kinematics is completely compatible with the principle of relativity.
Only a difference in the laws would be a violation of the principle, which as you stated earlier you were deliberately not doing. Since you used the same laws of physics in both frames in your scenario there is simply no logical way that you could possibly obtain a violation of the principle of relativity.
  • #61
AlMetis said:
Diagram 1.0 shows that does not happen.
The two-way convention calculates the one-way as a mean of each leg which sets the one-way time of flight the same for both observers. But as is shown in diagram 1.0 the one way time is not the same for both observers.
Once again, you are failing to understand the difference between asymmetries in experimenal results that are due to asymmetries you chose to put in your experimental setup, and the symmetry of the physical laws. (Which is the same point @Dale makes about boundary conditions in the post above this one).
  • #62
Dale said:
What you call reciprocal kinematics does not follow from the principle of relativity. I have already explained why, but I will do so again in more depth. ...
Thank you, that was an excellent explanation.
I agree with everything except your claim that the boundary conditions are different in my diagrams.
Time=0 shows identical boundary conditions except the arrow indicating the relative motion of A and B.
Please point out what boundary condition/s differ.
  • #63
That is a different boundary condition
The initial velocities of A, B, C, and D differ between the frames. Also, although it is not relevant for this problem, the initial times on the clocks would be different as would the length of the train. All of those are boundary conditions as described above
  • #64
vanhees71 said:
The entire discussion is just besides the point. The problem with Einstein's original paper of 1905 is that at this time nobody was aware about the mathematical structure which is adequate to formulate spacetime models, and that's why Einstein has to use pretty subtle gedanken experiments to establish the synchronization convention.
And it is for this reason that reading Einstein's papers is an exercise in the history of science, not the science itself. History of science is a fascinating discipline in its own right (and arguably more valuable to a well-rounded layperson than the science itself) but it is a different discipline with different goals and methods.
Likes vanhees71, Dale and Ibix
  • #65
Relative motion is a single condition, how can it differ between itself?
  • #66
There is only one velocity, the relative velocity of A and B.
A, C and D are the same frame, how can they differ from themselves.
  • #67
No, there are the velocities of the various things relative to your frames.
If I am in a car I might consider myself at rest. A pedestrian watching me drive by says I'm doing 30mph. Do you understand that? If so, what's the problem with your observers having different velocities with respect to different frames?
  • #68
C and D are at rest in the train's rest-frame and move in the ground's rest-frame. This creates different boundary conditions for the (frame-dependent) travel distances of the light and does not violate the 1st postulate.
  • #69
No. Suppose that, relative to A, B is moving to the right. Then, relative to B, A is moving to the left. These are two different relative velocities. They have the same magnitude, but opposite directions.
I think you have not really thought through what actually changes when you change frames.
  • #70
There are 2 frames A and B, one relative velocity.
  • #71
Sorry, my mistake.
B,C and D are the same frame.
  • Skeptical
  • #72
If that is the case, then the two diagrams show two velocities, the same velocity, one from each of two frames.
  • Sad
Likes Dale
  • #73
AlMetis said:
Sorry, my mistake.
In your diagram, A, C and D are at rest in the the same frame.
  • #74
If you mean your two diagrams in post #29, no, they don't. They show what I described, except that you have A moving to the right relative to B (in your Diagram 1.0) and B moving to the left relative to A (in your Diagram 2.0).
You really need to take a step back and think carefully. You are repeatedly making wrong claims and this thread cannot go on indefinitely with you simply continuing to repeat your wrong claims even after they have been repeatedly corrected.
Likes Dale
  • #75
Yes, they are in the same frame. It was my last post that was the mistake. I misunderstood your post.
To your last post - A, C and D do not change between frames of reference at time=0.
The motion between the two frames is what causes the different times of flight, but C and D remain in the rest frame of A.
  • #76
There are also velocities relative to frames, which is what you're transforming.
Do you understand that my velocity in a car can be zero in one frame and 30mph in another? Because I'm really not convinced you accept anything that basic.
Likes Dale and russ_watters
  • #77
If A moves to the right relative to, they observe B moving to the left and vise versa. How is that not correct?
  • #78
I do understand it. I don't understand why you think there is any conflict with that basic premise and what is described in the diagrams.
  • #79
I didn't say that wasn't correct. It is. But it contradicts your earlier claim here:
  • #80
The velocity of B relative to A is the same as the velocity of A relative to B. There is not a velocity “attached” to each, there is an observed velocity between them. They agree on this velocity and it is identical. If I was wrong in saying it is the one and the same, I stand corrected.
  • #81
So you understand that the receivers have different velocities in the two frames, and hence that the distances from emission to reception events can be different in the two frames? And hence that the reception events can be simultaneous in one frame and not in the other?
  • #82
No, it is not. You have already stated otherwise and your own diagrams show otherwise. You are contradicting yourself.
  • #84
After moderator review, the thread will remain closed.
  • Love
Likes russ_watters and malawi_glenn
  • #85
Sorry about the late post, but I wanted to follow up on the statements about boundary conditions.
No, relative motion is not the boundary condition. The boundary conditions include the initial position and initial velocity of each object of interest in the frame in which you are solving the equations of motion, as I mentioned in post 60.
The solutions to the differential equations don’t care about the relative velocity, they care about the variables (position), their initial values (initial positions), and their initial first derivatives (initial velocities), all in the specified frame. All of your recent comments about relative velocity are irrelevant regarding the boundary conditions and the equations of motion (your kinematics).
Hence, the boundary conditions are different in the two frames, but the laws of physics are the same. This is consistent with the principle of relativity.
Sure, that is a bit of a personal preference. A, B, C, and D all have different positions, so their positions are separate variables. So I would use their initial positions and initial velocities as separate boundary conditions and use constraint equations to set the appropriate velocities equal.
Directly using the reduced boundary conditions without explicit constraints will get you equivalent equations of motion either way, but it is a less systematic approach in my opinion.
Also in my opinion, you could use a bit more of a systematic approach. Your current approach seems very unproductive. You learn very little and very slowly. And the cost of what little you do learn is the good-will of this community of helpful experts. I hope you will be willing to modify your approach when you return
