- #666
- 8,616
- 4,649
eloheim said:I can’t understand how the TI is supposed to solve the problems of other interpretations, beyond merely decreeing, “It’s resolved. Don’t worry about it.”
No interpretation explains this, except by voicing the mantra ''nonlocality''. How Nature manages to realize these nonlocal coincidences is a secret of its creator. Bell's analysis just shows that one needs explicitly nonlocal beables if one wants to avoid all sorts of other weird assumptions. Nonlocal beables depends on simultaneous values at very far away points, and once one acknowledges that these influence local beables, nonlocal correlations between the latter are explained (in some sense).eloheim said:Essentially my question is, “how are these coincidences explained by the TI?”
The TI is nonlocal enough to be consistent with these findings. Moreover, it explains why there is nothing to worry about, since the usual worry has to do with a seeming incompatibility with special relativity. But there is no such incompatibility, as discussed in Subsection 4.4-4.5 of Part II. Thus Nature can consistently be relativistic and have nonlocal coincidences of Bell type.
How does this pointing provide an explanation? It only says that certain dynamical calculations leads to the result, but does not explain the result, unless calculation is deemed explanation. (But the same calculations then work for the TI.)eloheim said:Other interpretations point to the entangled particles, or a pilot wave
The problem you posed in your post is not the measurement problem but the nonlocality puzzle.eloheim said:the TI is billed as solving the measurement problem
The measurement problem is the problem of why there are unique and discrete outcomes for single quantum systems although the wave function produces only superpositions of (measurement,detector state) pairs. This problem is solved by the TI; see Subsection 5.1 of Part III and Section 3 of Part IV.
