MHB The Union of Two Open Sets is Open
  • Thread starter Thread starter G-X
    Sets Union
The discussion centers on proving that the union of two open sets, A1 and A2, is also open. It establishes that for any point x in the union A1 ∪ A2, if x belongs to either A1 or A2, there exists an open ball B(x,r) that is contained within the union. This is based on the definition of an open set, which requires that for every point in the set, an open ball can be found within it. The argument clarifies that the existence of open balls for each point in A1 and A2 ensures that the entire union is open. Therefore, A1 ∪ A2 is confirmed to be an open set.
G-X
Let [Math]x ∈ A1 ∪ A2[/Math] then [Math]x ∈ A1[/Math] or [Math]x ∈ A2[/Math]
If [Math]x ∈ A1[/Math], as A1 is open, there exists an r > 0 such that [Math]B(x,r) ⊂ A1⊂ A1 ∪ A2[/Math] and thus B(x,r) is an open set.
Therefore [Math]A1 ∪ A2[/Math] is an open set.
How does this prove that [Math]A1 ∪ A2[/Math] is an open set. It just proved that [Math]A1 ∪ A2[/Math] contains an open set; not that the entire set will be open? This is very similar to the statement: An open subset of R is a subset E of R such that for every x in E there exists ϵ > 0 such that Bϵ(x) is contained in E.
Mathematics news on Phys.org
The point is that the argument is valid for every $x\in A_1\cup A_2$.
If $C = A_1\cup A_2$, we have proved that, for every $x\in C$, there is an open ball $B(x,r)\subset C$ (where $r>0$ depends on $x$). That is precisely the definition of an open set.
Hi G-X, welcome to MHB!As castor28's pointed out, it's about the definition of an open set, which he effectively quoted.Additionally that proof is not entirely correct and it is incomplete.
It should be for instance:
If [Math]x ∈ A1[/Math], as $A1$ is open, there exists an $r > 0$ such that [Math]B(x,r) ⊂ A1[/Math] (from the definition of an open set), which implies that [Math]B(x,r)⊂ A1 ∪ A2[/Math].
If [Math]x ∈ A2[/Math], as $A2$ is open, there exists an $r > 0$ such that [Math]B(x,r) ⊂ A2⊂ A1 ∪ A2[/Math].
Therefore for all [Math]x ∈ A1∪ A2[/Math], there exists an $r > 0$ such that [Math]B(x,r) ⊂ A1 ∪ A2[/Math].
Thus [Math]A1 ∪ A2[/Math] is an open set.
I see, I think I had the misunderstanding that something from A2 might close A1.
But I don't think that is an issue you technically need to wrap your head around.
Because the definition states: We define a set U to be open if for each point x in U there exists an open ball B centered at x contained in U.
So, essentially looping over A1, A2 - making the reference that open balls exist at each of these points then all points in A1 ∪ A2 have open balls contained in the union thus by the definition it must be open.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
