Insights The Vacuum Fluctuation Myth - Comments
  • #201
PeterDonis said:
No, it isn't. The scalar field is the fundamental object. "Virtual particles" is just a shorthand way of describing particular things that arise in a particular approximation.
You are making the common mistake of equating "quantized" with "discrete". That's not what quantization means.
From the standpoint of quantum field theory, quantum fields (of which the scalar field is one) are the fundamental objects. "Particles" and "waves" are just names for particular kinds of quantum field states, and there are quantum field states that are not aptly described by either of those names.
http://wikidiff.com/quantum/discrete
As adjectives the difference between discrete and quantum
is that discrete is separate; distinct; individual; non-continuous while quantum is of a change, sudden or discrete, without intermediate stages.
I think I used quantum/quantized in the appropriate way.
Discrete things do not have to be of the same size. But quantum things (quanta) are supposed to be of the same size, like fundamental units or fundamental blocks. Because of that, they are like fundamental deltas or units of change.
  • #202
https://en.m.wikipedia.org/wiki/Quantum
In physics, a quantum (plural: quanta) is the minimum amount of any physical entity involved in an interaction. The fundamental notion that a physical property may be "quantized," referred to as "the hypothesis of quantization".[1] This means that the magnitude of the physical property can take on only certain discrete values
How can you possibly apply the above to a VP ?
  • #203
Some people still seem to think vacuum fluctuations are a real thing.
• Theoretical estimates of various contributions to the vacuum energy density in QFT exceed the observational bound by at least 40 orders of magnitude. This large discrepancy constitutes the cosmological constant problem. One can distinguish at least two different meanings to the notion of a cosmological constant problem:
1. Calculations of Λ = 8 π G ρvac from assuming real QFT vacuum fluctuations, lead to a huge fine-tuning problem.
John Moffat
The value of the cosmological constant is infamously the worst prediction ever made using quantum field theory; the math says it should be 120 orders of magnitude larger than what we observe.
Sabine Hossenfelder
https://twitter.com/skdh
  • #204
Yes, it's very hard to get wrong ideas from popular-science books (sometimes even textbooks!) out of the minds of people. Some famous guy (Feynman?) said, that for any problem there's a simple solution, which is wrong.
Likes bhobba and Drakkith
  • #205
I don't see where the second quote would imply vacuum fluctuations. We cannot really predict a cosmological constant from QFT, but if it is non-zero, the natural scale would be the Planck density.
  • #206
I have a closely related question. In the insight it is mentioned that generally, inside a superposition nothing dynamical happens. But what if the wave function is time dependent, for instance an electron in the double slit experiment, do fluctuations in the quantum state happen then?
  • #207
In this case the wave function changes deterministically. The wave function of the spin of an electron changes very smoothly with time, except at the moment of measurement, where it changes randomly. But this randomness has nothing to do with vacuum fluctuations.
Likes QuantumQuest and durant35
  • #208
But would you still say that nothing dynamical happens inside the wavefunction before the measurement, even if we take into account the deterministic evolution you mentioned?
It's not like the electron is jumping from one spot to anothee. It literally is in a state without a definite position, right?
  • #209
The wave functions evolve according to Schrödinger's equation (i.e., unitary time evolution). I don't know what you mean by "nothing happens inside the wave function". The Schrödinger equation is describing the dynamics of the system.
According to quantum theory nothing is jumping at all. It's another bad idea from "old quantum theory" that should not be used in any modern physics curriculum anymore. Indeed an electron has never a definite position (although in principle it can be quite localized, because it's a massive particle and thus admits the definition of position as an observable). Within non-relatistic quantum theory the position-probability distribution is given by .
Likes QuantumQuest
  • #210
The smooth evolution of the wave function is dynamically happening while it passes a magnet. It is not the wave function but the intuitive semiclassical picture of an electron as a moving point that ''causes'' the apparent jumps.
To say that the electron has no definite position just means that one cannot think of it as being a point. The position of an electron is as well-defined as that of a cloud - it is located in a well-defined region but not in a well-defined point. Only the latter would have a definite position. Thus if one wants a more valid intuitive picture one needs to consider an electron as a smoothly changing cloud distributed over all electron rays with a non-negligible mass density, and contracting to a small spot upon measuring.
Likes vanhees71 and durant35
  • #211
Got it. To me, to say that the electron ia fluctuating in its position is roughly to say that it is jumping between one position and another when not measured which is clearly related to the semiclassical picture you (and vanhees) described. And which is of course false.
When I said nothing happens in the wf, I meant that. Electron isn't jumping between the spots, it literally is in a state of variance which may change over time. But it is still only a variance - nothing happens 'inside' the wf. This is a different context of happening than deterministically evolving which applies to the wf as a whole. For something to happen, you need measurement. Would you agree with this line of reasoning?
  • #212
No. In more complicated contexts, a lot may happen, and this is expressed in the evolution of the state. Indeed, ''the moment of measurement'' is itself a gross simplification of a very complicated interaction that happens between the electron and the measurement device, described not by the state of the electron alone but by the state of the combined system electron+device+environment. The apparent randomness in the fate of the electron state alone is due to this additional complexity.
  • #213
I used to know a bit about the "toy model" QFT in 1+1 dimensions (Glimm & Jaffe). They rigorously construct interacting particle states with bound states and scattering. AFAIK there is nothing corresponding to vacuum fluctuations in this mathematically well defined theory. I can't think how you could even rigorously ask "are there vacuum fluctuations?" in this context.
"Vacuum fluctuations" seem to be an artifice of trying to apply perturbation theory when you don't know that the perturbed theory is mathematically well defined.
  • #214
Keith_McClary said:
I used to know a bit about the "toy model" ##\phi^4_2## QFT in 1+1 dimensions (Glimm & Jaffe). They rigorously construct interacting particle states with bound states and scattering. AFAIK there is nothing corresponding to vacuum fluctuations in this mathematically well defined theory. I can't think how you could even rigorously ask "are there vacuum fluctuations?" in this context.
Vacuum fluctuations refer to the fact that smeared field operators have in the vacuum state a nonzero variance. This is captured by the Wightman distribution functions, hence a fact even in QFT in 1+1 dimensions.
On the other hand, interpreting (as in most popular accounts of quantum phenomena) these vacuum fluctuations as happenings in time is completely fictitious.
Likes jtbell
  • #215
If vacuum fluctuations are fictitious, then what is the proper explanation of the Casimir effect?
  • #217
Its actually a manifestation of Van Der Walls forces you probably learned about in HS chemistry::
https://arxiv.org/pdf/hep-th/0503158v1.pdf
'The Casimir effect is a function of the fine structure constant and vanishes as α → 0. Explicit dependence on α is absent from eq. (3) because it is an asymptotic form, exact in the α → ∞ limit. The Casimir force is simply the (relativistic, retarded) van der Waals force between the metal plates'
See also:
https://arxiv.org/abs/1605.04143
Thanks
Bill
  • #218
Thank you Dr. Neumaier and Dr. Bill for taking the time to respond to my post. I have been perplexed and annoyed by the term "vacuum fluctuation" for many years. After reading the paper by Jaffe my angst has been lifted and I have a renewed appreciation for the incredible predictive power of QFT. Alhamdu lila!
Salam,
Fred
  • #219
A. Neumaier said:
Vacuum fluctuations refer to the fact that smeared field operators have in the vacuum state a nonzero variance. [...]
The source of this (mis)interpretation is surely the fact that in normal English usage, the word "fluctuation" does mean "variation with respect to time." At least, that's how I always understand it in everyday language.
This is of course not the only case in people are confused by the re-purposing of everyday words into physics jargon with specific technical meaning. Consider "work", "energy", and "power", which introductory physics students often struggle with at first. Or "speed" and "velocity".
  • #220
The word vacuum is also problematic when you look at the definitions from classical to quantum.
  • #221
Fred Wright said:
Dr. Bill
Many that post here have doctorates, including Dr. Neumaier. I however am not one. Just a guy with a degree in applied math and computing who is now retired from 30 years spent programming, so can indulge his fascination for and interest in physics.
Thanks
Bill
