The velocity of transverse waves on a string
The discussion focuses on calculating the velocity of transverse waves on a violin string that is 35 cm long and has a mass of 2.0g, producing the note A4 at 440 Hz. The mass per unit length (ρ) of the string is calculated to be 0.0057 kg/m. Participants suggest using the formula v = √(F/ρ) but express uncertainty about determining the force (F) needed for this calculation. An alternative approach is proposed, using the relationship between frequency, wave velocity, and string length, expressed as f = v/(2L). This method may provide a more straightforward solution for finding wave velocity.
Nikles
1. A violin string is 35 cm long between its fixed ends and has a mass of 2.0g. The string sounds the note A4 (440 Hz) when played.
v=\sqrt{}F/ρ
I calculated ρ, mass per unit length, to be .0057 kg/m but do not know how to find the force that I need to plug into the equation.
Another formula (related to the one you mentioned, but derived from the wavelength) gives the wave velocity directly in terms of the freqency and string length. Try this one?
$$ f = \frac{v}{2 L} $$
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
