The voltage and current caused by a wave? Does distance matter?
When a wave is transmitted from an antenna with a 5V amplitude, receivers at different distances will not register the same current. The voltage at both receivers will remain the same, but the current will decrease for the receiver that is farther away due to the inverse square law affecting signal strength. Additionally, the energy per unit area of the wave diminishes with distance from the source, impacting the current received. Therefore, while voltage remains constant, current varies with distance. Understanding these principles is crucial for analyzing wave transmission and reception.
bsmith
If a wave is transmitted from an antenna with an amplitude of 5v and a receiver at 10 meters away and another is at 20 meters away picks the signal up. If they are the exact same receivers, will they register the same voltage? Will they register the same current?
Im going to say the voltage will be the same but the current will be lower in the one that is farther away.
How does the energy per unit area of the wave vary with distance from the source?
AM
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
