The Work-Energy Theorwm and Kinetic Energy
The discussion revolves around calculating the work done to launch a hammer and a bullet using the work-energy theorem. The hammer, weighing 7.3 kg and thrown at a speed of 29 m/s, has its kinetic energy calculated as KE = (1/2)mv^2, resulting in approximately 3069.65 J. The initial kinetic energy for both the hammer and the bullet is zero since they start from rest. The bullet, weighing 2.6 g and exiting a gun at 410 m/s, can be analyzed similarly to find its kinetic energy. The conversation highlights the application of the work-energy theorem in determining work done in both scenarios.
pstfleur
1. The hammer throw is a track-and0field event in which a 7.3-kg ball (the hammer), starting from rest, is whirled around in a circle several times and released. It than moves upward on the familiar curvinf path of projectile motion. In one throw, the hammer is given a speed of 29 m/s. For comparison, a .22 caliber bullet has a mass of 2.6g and, starting from rest exits the barrel of a gun with a speed of 410 m/s. Determine the work done to launch the motion of (a) the hammer and (b) the bullet.
2. KE=(1/2)mv^2
W= KE(final)-KE(initial)
3. I think I know my KE final, which would be just plugging in the numbers-
(1/2)*(7.3kg)*(29^2)=KE(final) of the Hammer... But How would I get my KE(initial) since I don't know what the initial velocity of the hammer is as its being whirled around in a circle.
Can someone help?
Both hammer and bullet start from rest.
OK WOW, clearly I input some wrong numbers in my calculator..
Thanks for the help Doc..Sorry for wasting ur time
I guess Ill go ahead and answer the rest of the Question...
KE=(1/2)mv^2
W=Ke final- Ke initial
W= (1/2)(7.3kg)(29^2)
=3069.65 or 3.1*10^3 for the Hammer..
You can use the same to Find KE final for the Gun..
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
