Agent Smith
- 336
- 36
Inviting comments as well
What are the master equations of QED and QCD? TOE has to include both of them and therewith all equations of both. How could this be reduced to one equation if the parts don't already have one?Agent Smith said:String theory? One (master) equation?
Put all the equations that you need into an action and call it for the day. You know what, let us write all equations known to humans asfresh_42 said:What are the master equations of QED and QCD? TOE has to include both of them and therewith all equations of both. How could this be reduced to one equation if the parts don't already have one?
Determining the exact form of ##\Phi## is left as an exercise for the reader.pines-demon said:Theory of everything done.
Will be difficult to press Heisenberg's uncertainty principle into that scheme, or the concept of dimensions.pines-demon said:Put all the equations that you need into an action and call it for the day. You know what, let us write all equations known to humans as
$$\Phi(\mathbf S)=0$$
where ##\Phi## is the operator that sends all variables ##\mathbf S=(S_1,S_2,\cdots)## to its corresponding equation. Theory of everything done.
You should put this tee-shirt on your Christmas wish list:fresh_42 said:What are the master equations of QED and QCD? TOE has to include both of them and therewith all equations of both. How could this be reduced to one equation if the parts don't already have one?
I never said that ##\Phi## had to be linear or that the ##S_i## had to be independent variables. I can accommodate as many equations and dimensions as you wish.fresh_42 said:Will be difficult to press Heisenberg's uncertainty principle into that scheme, or the concept of dimensions.
Do you know which one?Hornbein said:This facetious idea is in one of Richard. Feynman's book.
I read them about 30 years ago so I don't recall which.pines-demon said:Do you know which one?
##x^2 + y^2 + k_1 a + k_2 b = k_3##fresh_42 said:What are the master equations of QED and QCD? TOE has to include both of them and therewith all equations of both. How could this be reduced to one equation if the parts don't already have one?
Electricity and magnetism were unified by a series of experimental discoveries by Ørsted, Faraday and Ampère. Maxwell took hundreds of equations of electromagnetism and compiled them into 20 or so (Heaviside reduced them into 4). Maxwell using his equations unified electromagnetism with light waves (and EM radiation in general).Agent Smith said:Is it true that Maxwell "united" electricity and magnetism into electromagnetism using the concept of fields?
Barely, Hamilton did work on optics. Maxwell used a bit of Hamilton's quaternion algebra but not much.Agent Smith said:Did Rowan Hamilton have a role in this?
Volume II, Chapter 25 (Electrodynamics in Relativistic Notation), Section 25-6Hornbein said:I read them about 30 years ago so I don't recall which.
Let us show you something interesting that we have recently discovered: all of the laws of physics can be contained in one equation. That equation is\begin{equation}
U = 0 \tag{25.30}
\end{equation}What a simple equation! Of course, it is necessary to know what the symbol means. ##U## is a physical quantity which we will call the “unworldliness” of the situation. And we have a formula for it. Here is how you calculate the unworldliness. You take all of the known physical laws and write them in a special form. For example, suppose you take the law of mechanics, ##F = ma##, and rewrite it as ##F - ma = 0##. Then you can call ##(F - ma)##—which should, of course, be zero—the “mismatch” of mechanics. Next, you take the square of this mismatch and call it ##U_1##, which can be called the “unworldliness of mechanical effects.” In other words, you take\begin{equation}
U_1 = (F - ma)^2 \tag{25.31}
\end{equation}Now you write another physical law, say, ##\nabla \cdot \mathbf{E} = \frac{\rho}{\varepsilon_0}##, and define\begin{equation*}
U_2 = \left( \nabla \cdot \mathbf{E} - \frac{\rho}{\varepsilon_0} \right)^2
\end{equation*}which you might call “the Gaussian unworldliness of electricity.” You continue to write ##U_3##, ##U_4##, and so on—one for every physical law there is. Finally, you call the total unworldliness ##U## of the world the sum of the various unworldlinesses ##U_i## from all the subphenomena that are involved; that is, ## U = \sum U_i##. Then the great “law of nature” is\begin{equation}
U = 0 \tag{25.32}
\end{equation}This “law” means, of course, that the sum of the squares of all the individual mismatches is zero, and the only way the sum of a lot of squares can be zero is for each one of the terms to be zero.
So the “beautifully simple” law in Eq. (25.32) is equivalent to the whole series of equations that you originally wrote down. It is therefore absolutely obvious that a simple notation that just hides the complexity in the definitions of symbols is not real simplicity. It is just a trick. The beauty that appears in Eq. (25.32)—just from the fact that several equations are hidden within it—is no more than a trick. When you unwrap the whole thing, you get back where you were before.
I've been watching a video on Rowan Hamilton(ian) and Action - "a new way of looking at physics" (?).pines-demon said:Electricity and magnetism were unified by a series of experimental discoveries by Ørsted, Faraday and Ampère. Maxwell took hundreds of equations of electromagnetism and compiled them into 20 or so (Heaviside reduced them into 4). Maxwell using his equations unified electromagnetism with light waves (and EM radiation in general).
Can you link the video?Agent Smith said:I've been watching a video on Rowan Hamilton(ian) and Action - "a new way of looking at physics" (?).
Gravity waves were studied at the time of Newton, and the mathematics were simplified by Lagrange, Poisson and Laplace much before Hamilton. However you are probably referring to gravitational waves (gravity waves refers to surface waves in water). Gravitational waves were not considered until the 20th century.Agent Smith said:Maybe gravity waves?
I see. Thanks. Yes I think I meant gravitational waves (LIGO).pines-demon said:Can you link the video?
They felt like doing it.Agent Smith said:I wonder why Einstein was trying to find the ToE? His disciples are too.
When you think you are so smart that you revolutionize our perspective of space-time twice you may think that the next problem might be just of the same difficulty.Agent Smith said:I wonder why Einstein was trying to find the ToE? His disciples are too.
They all did to some extent?pines-demon said:When you think you are so smart that you revolutionize our perspective of space-time twice you may think that the next problem might be just of the same difficulty.
