Therefore, the volume of the rectangular prism is 84 units cubed.
In summary, the surface area of a rectangular prism with dimensions $\ell=6$, $w=2$, and some unknown height $h$ is 136 square units. Using this information, we can solve for $h$ and find the volume to be 84 units cubed.
What is the answer to this question. The surface area of a rectangular prism is 136 square units. Some edge measurements are 6 and 2.What is the volume?
Mathematics news on Phys.org
Re: Math homework
We are not here to do your homework. We can, however, guide you through.
So what have you been able to do with this problem so far?
-Dan
Re: Math homework
I got the answer 84units3 (or cubed)
Re: Math homework
The dimensions are length $\ell$, width $w$ and height $h$. Suppose we know $\ell$ and $w$ to be 6 and 2 respectively. A rectangular prism (cuboid) has 3 pairs of matching faces, and it surface area $A$ is given by:
\(\displaystyle A=2(\ell w+\ell h+wh)\)
Using the given surface area and $\ell$ and $w$, we may state:
\(\displaystyle 136=2(6\cdot2+6h+2h)\)
\(\displaystyle 68=12+8h\)
\(\displaystyle h=7\)
And so the volume $V$ (in units cubed) is given by:
\(\displaystyle V=\ell wh=6\cdot2\cdot7=84\quad\checkmark\)
FAQ: Therefore, the volume of the rectangular prism is 84 units cubed.
What is the formula for finding the volume of a rectangular prism?
The formula for finding the volume of a rectangular prism is length x width x height.
How do you measure the length, width, and height of a rectangular prism?
The length, width, and height of a rectangular prism can be measured using a ruler or measuring tape. Make sure to measure from the longest point to the longest point for length and width, and from the bottom to the top for height.
What units are used to measure the volume of a rectangular prism?
The volume of a rectangular prism is usually measured in cubic units, such as cubic centimeters (cm³) or cubic meters (m³).
Can the volume of a rectangular prism be negative?
No, the volume of a rectangular prism cannot be negative. It is a measure of the amount of space inside the prism, so it is always a positive value.
Can the volume of a rectangular prism be calculated if only two dimensions are known?
No, the volume of a rectangular prism cannot be calculated if only two dimensions are known. You need all three dimensions (length, width, and height) in order to find the volume.
