- 22,372
- 7,223
I was watching some videos about aircraft performance and found a common theme - rapid or sudden cooling - of piston engine heads (there is some disagreement/controversy on the subject) or turbine stators, leading to component or performance failure.
The Focke-Wulf Fw 190 A-4 had a performance problem with the use of methanol-water injection (in the supercharger), a technique which was introduced in fighter aircraft of WWII.
The video references a Lycoming page on the subject of rapid or sudden cooling of hot engine parts.
https://www.lycoming.com/content/how-avoid-sudden-cooling-your-engine
https://en.wikipedia.org/wiki/Shock_cooling
https://en.wikipedia.org/wiki/MW_50
Rapid cooling of a cylinder head may result in thermal fatigue, crack initiation and subsequent propagation. On the other hand, over-pressure with respect to design could increase the stress to the point where crack initiation might occur.
The second effect, core lock, happens when a hot engine shuts off under cold conditions, in which the stator or housing cools rapidly and shrinks (thermal contraction) onto a hot rotor (shaft or spindle in the hot (turbine) zone). It is difficult or impossible to restart an turbo jet engine if the stator shrinks onto the hot turbine discs and/or shaft. This is was on aspect of a crash involving a CRJ aircraft that flew too high (upper service flight level of 41000 ft), at too steep an angle, resulting in both engines flaming out. The cooling of the engines at altitude locked the rotors such that the engines could not be restarted, and the plane eventually crashed.
https://en.wikipedia.org/wiki/Core_lock
Note: there are various issues with the Wikipedia articles. Nevertheless, the subject matter is interesting and should be appreciated by pilots and aircraft designers/engineers.
