Thermodynamic Query: Calculating Heat Transfer for Monoatomic Gas at S.T.P.
  • Thread starter Thread starter shrutiphysics
    Thermodynamic
The discussion revolves around calculating the net heat transfer for a monoatomic gas under specific conditions at standard temperature and pressure (S.T.P.). Initially, the temperature of one gram molecule of gas is raised by 1K at constant volume, followed by the addition of another gram molecule isothermally. Participants express confusion over the heat transfer calculations, particularly regarding work done during the isothermal process and the lack of clarity on how the gases are combined. The final consensus suggests that the net heat transfer for the entire process is 3 times the specific heat at constant volume. The problem is noted to be poorly defined, lacking details on the combination of gases.
shrutiphysics
one gram molecule of monoatomic gas is taken at s.t.p. keeping its volume constant,its temperature is raised by 1k. one gram molecule of the gas is added isothermally to this.the mixture is now cooled by 1k at constant volume to return to s.t.p. if [c][/v] be gram molecular specific heat of gas constant volume, net heat transfer in the whole process is??
my solution: for 1st step- w=o,q=u=n[c][/v]dt=[c][/v]
2nd step-i don't know what will be q=?..as u=0, q=w, but how to find w?
3rd step-q=2[c][/v]
What is the volume occupied by one gram molecule of a gas at s.t.p?
When you add some more gas, what happens to P, V, T? (T is constant since process is isothermal).
Once you have have found final volume, then use ##W=\int PdV##
This is a very poorly defined problem. You are not told how the two gases are combined. It could be at constant pressure, for all we know. That is the simplest case to consider.
Chet
Likes AdityaDev
volume at stp. is 22.4l. since we add 1mole gas it becomes 44.8l then should i use w=nrtlogv2/v1 (work done is isothermal process).
but if i use this answer is not coming.
i also thought that q=msdt and since temperature in second step is constant so q=0. is this correct??
the answer given is 3[c][/v].
Chet
i am sorry but this is how the question was given in my book
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
