Thermodynamics - Saturated Vapor Quality Question
The discussion centers on calculating the quality of saturated vapor in a rigid vessel containing both liquid water and water vapor at a specified pressure. The correct method involves determining the mass of the liquid and vapor using their respective specific volumes, leading to a quality calculation of approximately 0.05818. Confusion arises from an alternative method using specific volumes, which yields a different result of 0.9147, prompting questions about its validity. A participant identifies an error in their specific volume calculation, ultimately confirming that the correct quality is indeed 0.05818. The conversation highlights the importance of accurate specific volume computations in thermodynamic quality assessments.
MechE2015
A 4 cubic meter rigid vessel contains 0.04 cubic meters of liquid water and 3.96 cubic meters of water vapor at 101.325 kPa. What is the quality of the saturated vapor?
Specific volume of saturated liquid at 100 C and 101.325 kPa: 0.001044 m^3/kg
Specific volume of saturated vapor at 100 C and 101.325 kPa: 1.67290 m^/kg
Mass of Vapor = (Volume vapor) / (Specific Volume of sat. vapor)
Mass of water = (Volume water) / (Specific Volume of sat. liquid)
x = (Mass of Vapor) / (Total Mass)
Mass of liquid: 0.04/0.001044 = 38.314 kg
Mass of vapor: 3.96/1.67290 = 2.367 kg
x = 2.367/(38.314+2.367) = 0.05818
Also, for some reason, I thought the quality could be found by specific volumes, which would give me: x = (1.5313-0.001044)/(1.6729) = 0.9147
Could anyone tell me which method is correct? We have used specific volume to find the quality a few times, which confuses me as to why this would be different.
That looks right to me. :approve: (ignoring any trivial rounding differences, if any)
Forgive me, but I have no idea what you're doing there. You'll have to explain your reasoning.
@collinsmark
I think I had an error computing the specific volume, and if I correct it with the specific volume of 0.09833 m^3/kg, the I get a quality = (0.09833 - 0.001044) / (1.6729 - 0.001044) = 0.05818
Sorry for the confusion but I think I found my mistake with the incorrect computation for specific volume.
MechE2015 said:
@collinsmark
Okay. But where does the the 0.09833 m3/kg come from? It's the specific volume of what exactly? Again, forgive me, but I'm just not following.
  • · Replies 44 ·
  • · Replies 22 ·
