Liquidxlax
- 322
A steel bar of rectangular cross-section, with height a and width b (into the paper), is placed on a block of ice with its ends extending a little beyond the ice, (ice has a length c). A weight of mass m is hung from each end of the bar. The entire system is at 0 degrees celcius.
As a result of the pressure exerted by the bar, the ice melts beneath the bar and refreezes above the bar. Heat is therefore liberated above the bar, conducted through the metal, and then absorbed by the ice beneath the bar. Given the latent heat of fusion per kilogram of ice (L), the density of ice ρi, the density of water ρw, the thermal conductivity of steel (Kappa) which relates the heat q crossing a unit area per unit time to the temperature gradient (dT/dz) in a direction perpendicular to the plane through the relationship q=-(kappa)(dT/dz), the temp T(=0 degrees celcius) of the ice, the accelertation due to gravity g, the mass m, and the dimensions a, b, and c, where c is the length of the block of ice, show that the speed v with which the bar sinks through the ice is
v= [(2mg(kappa)T)/(abcL2ρi)]*[(1/ρi)-(1/ρw)]
A=bc
dP/dT = L/TΔV ~ ΔP/ΔT
dq = -(kappa)(ΔT/Δz) ( my prof wrote it as q with a dot over top so i assume it's some sort of dq)
(dQfusion/dt) = (dM/dt)(L/A)
Everytime i look at it, i don't see a constant velocity since the pressure should be increasing therefore the temperature below the bar would be increasing. anyways
I thought to try and relate the equations with ΔT to get rid of the ΔT
so,
dq= -(kappa)(ΔT/Δz) = -(kappa)([ΔPTΔV]/LΔz)
then for the dQfusion i thought to multiply through by dt and equate the above equation dq to dQfusion
so
dz= -(kappa)*([ΔP*T*ΔV*A]/[dM*L2)
then i thought that ΔP has to be 2(dM)g/A or 2mg/A (since it's in the top of the answer)
ΔV = Adz
that's all i have and i don't think it's right.
any help would be appreciated
