Engineering Thevenin equivalent circuit parameters
The discussion focuses on determining the Thevenin equivalent circuit parameters, VTh and RTh, for a given circuit. A participant describes their process of converting a current source to a voltage source, calculating it as 20V based on the current and resistance values. Confusion arises regarding the polarity of the voltage source during this conversion. Other participants clarify that the polarity should be adjusted to reflect the current direction and emphasize the need to simplify the circuit further by resolving the voltage divider. The conversation concludes with the importance of correctly redrawing the circuit to accurately represent the Thevenin equivalent.
Narks
https://www.physicsforums.com/attachment.php?attachmentid=32837&stc=1&d=1299373667
Determine the Thevenin equivalent circuit parameters, VTh and RTh, referred to terminals A and B of the circuit shown below?
My only question is this step:
https://www.physicsforums.com/attachment.php?attachmentid=32838&stc=1&d=1299373667
Converted current source to voltage source (V = IR = 10 x 2 = 20 V), then combined the 10 ohm and 5 ohm resistor.
I'm pretty sure I've just ignored the polarity of the current source to get here - I've always been confused as to what to do with converting sources and polarity. Is this correct? If not, what is the proper way to convert the current source to a voltage source (assuming that is the correct method to solve the problem)?
Thanks!
ya, that looks right. Just think that the 2 amps is making a loop through the 10 ohm resistor. If you made a circle on the left loop with an arrow pointing in the same direction as the current source. The current would go up through the 10 ohm resistor. So put your voltage source so the + side is pointing up.
1. The polarity of the voltage source in the second figure should be reversed.
2. You're not done yet. You've still got to resolve the 15Ω/5Ω voltage divider into a single resistance and voltage source.
Change your current source into a voltage source, which should give you a 20V voltage source. When you redraw the circuit, put the resistor in series with the voltage supply and that will give you the voltage divider that gneill was referring to.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
