Thin Lens & Images: Real, Inverted & Smaller Objects
A thin converging lens forms a real image when the object is placed outside the focal length. It also produces an inverted image under the same condition. For the image to be smaller than the object, the object must be positioned outside twice the focal length. The responses provided in the discussion confirm the accuracy of these conclusions. This understanding is essential for solving related optics problems effectively.
Glen Maverick
Under what conditions will a thin converging lens form:
a) a real image,
b) an inverted image,
and c) an image smaller than the object?
none
I have concluded that:
a) the object needs to be outside the focal length
b) the same
c) the objects needs to be outside twice the focal length.
I am not sure if the answers are right. Can you please check for me? Thank you!
Your answers are correct.
Thank you to both Stanton and rl.bhat. I was looking for this problem. :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
