B Thought Experiment: Does Gravity's Compression Warm an Object?
The discussion explores whether a homogenous crystalline object in space, subjected to gravity's compressive force, would cool to the temperature of its surroundings or remain warm indefinitely. It questions if compression inherently warms an object, even when atomic movement ceases, and whether the presence of matter guarantees a temperature above that of surrounding space. A follow-up considers if gravity operates in pulses at a quantum level, potentially affecting the object's temperature similarly to how repeated bending warms glass. The conclusion suggests that, without nearby heat sources, the object would eventually cool to 2.725 degrees Kelvin. The thought experiment raises intriguing implications about the relationship between gravity, compression, and temperature.
Cayman
TL;DR Summary
Thought experiment and question concerning whether gravity causes a permanent temperature increase in matter.
Thought experiment:
(1.1) You have a homogenous object, made of one element, floating in space.
(1.2) Gravity has completed the process of accelerating its atoms and molecules into the final state, such that the object is a crystalline sphere.
(1.3) Gravity continues to act on the object, even though the atoms and molecules are now in positions that gravity cannot overcome or move.
Question: Does this object:
(2.1) cool to the temperature of the surrounding space or
(2.2) remain warm for ever due to the eternal compressive force on the object due to the eternal acceleration of gravity on its atoms and molecules?
Asked two other ways:
(3.1) Does compression always warm an object at any scale, even when the compressive force fails to move any of the object's atoms or molecules?
(3.2) Does the existence of matter always imply a temperature greater of the matter than of the surrounding space?
Follow-up question:
(4.1) If gravity occurs in pixels (quantum) and in waves, then this would suggests that, at some sufficiently small scale of time and space, gravity acts in pulses of squeeze and release. If so then would this contribute to an effect of "working" on a crystal, similar to warming up glass by bending repeatedly without breaking it?
Cayman said:
Summary:: Thought experiment and question concerning whether gravity causes a permanent temperature increase in matter.
Assuming it was not near any heat producing object then it would cool down to 2.725 degrees Kelvin
Likes vanhees71 and davenn
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
