Threshold Energy Calculation for Proton-Proton Collision
To calculate the threshold energy for the reaction p+p --> p+p+(pion), it is essential to apply conservation of momentum and energy using relativistic equations. The discussion highlights the challenge of starting the calculations, with emphasis on using the relativistic momentum and kinetic energy formulas. A suggested approach is to analyze the problem in a frame where the initial momentum is zero, allowing for easier calculations of final particle speeds. Despite attempts to set up the conservation of energy equation, the user struggles with cancellations leading to trivial results. The conversation underscores the complexity of applying relativistic physics to particle collision problems.
FreeAnnyong
When a beam of high-energy protons collides with protons at rest in the laboratory (e.g., in a container of water or liquid hydrogen, neutral pions are produced by the reaction p+p --> p+p+(pion). Compute the threshold energy of the protons in the beam for this reaction to occur.
I don't even know where to start with this one.
All attempts I've made are ridiculous because I didn't even know what equations to start with.
You still have conservation of momentum and mass/energy, but you have to use the relativistic equations for them. the momentum for a particle is
\gamma m_0 v and the kinetic energy is \gamma m_0 c^2.
It's probably easiest to work in a frame where the initial momentum is 0. In this frame the final speed of all the particles involved can be 0. You'll have to use the relativistic velocity addition formula to compute what the initial speeds in the lab frame must have been.
I've been trying your suggestion, and I'm still getting nowhere. I try setting up the conservation of energy equation but I keep ending up with everything canceling and I just get 0=0. I feel like a complete idiot, but I can't figure out what I'm doing wrong.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
10K
