Time constant for the current through the inductor
The discussion focuses on calculating the time constant for the current through an inductor in a circuit with a voltage of 6 volts, a resistance of 10 ohms, and an inductance of 100 mH. The correct formula for the time constant is established as τ = 2L/R. A participant initially suggests that the equivalent resistance is 2R, leading to a time constant of L/2R, but this is corrected to R/2, confirming the original time constant of 2L/R. The key takeaway is that the time constant for the current through the inductor is indeed 2L/R.
syhpui2
http://i.imgur.com/wjD8Y.png
In the circuit below, V = 6 volts, R = 10 ohms, L = 100 mH. The switch has been open for a long time. Then, at time t = 0, the switch is closed.
What is the time constant for the current through the inductor?
2L / R
TAU=l/R
I am not sure how do I find the equvialent resistance in this case.
Kill the source (short the voltage supply) and remove the inductor. Find the equivalent resistance at the terminals where the inductor was.
Equvialent resistance is 2r then time constant should be L/2R?
instead of 2L/R?
Thanks
instead of 2L/R?
Thanks
Nope. Those two resistors are not in series with respect to the open terminals. So the resistance is R/2. That makes your time constant 2L/R.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
