Time delay of speech to travel from moon to earth
Communication from the Moon to Earth experiences a delay of approximately 2.56 seconds due to the distance, as signals travel at the speed of light. Sound cannot travel in the vacuum of space, which is why there is no sound transmission between the Moon and Earth. All communications are conducted through electromagnetic signals, such as radio or microwave, which also travel at light speed. The average distance from Earth to the Moon is about 1.282 light-seconds. The vacuum of space is nearly devoid of matter, making it an effective medium for light-speed communication.
Black Hole
So if I'm on the moon is there a delay with the communication to earth?
What is the speed of sound over satellites verses copper wires?
Anyone know?, this has been on my mind.
thanks
k what ever u are communicating on will travel at the speed of light
so it will take about 2.56 seconds for that signal to reach earth.
Sound needs matter to travel through. Since the Moon and Earth are separated by the vacuum of space no sound can travel. Hence the saying "in space no one can here you scream". Any communications from Earth to the Moon will be done by sending a electromagnetic signal representing the data (radio, microwave, etc), which travel at the speed of light. Wikipedia tells me that "The average distance from the Earth to the Moon is about 1.282 light-seconds."
is the vacuum of space really a vacuum or is it the higgs field.
The proper saying is, "In space, no one can hear you scream unless it is the battle cry of a United States Marine Corps Space Aviator!" - R. Lee Ermey, from Space: Above and Beyond.
A Vacuum is defined as an absence of matter. Higgs field has nothing to do with it. And while space is NOT a perfect vacuum, it is about as perfect as you can get. The density of matter in space varies depending on how close you are to stars, planets, nebulas, ETC. Inter galactic space (Space between galaxies) is supposedly the best vacuum possible I believe.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
