I Time-dependent to time-independent Schrödinger equation
LagrangeEuler
Why you can do separation of variables in time-dependent
i \hbar \frac{\partial \psi(\vec{r},t)}{\partial t}=-\frac{\hbar^2}{2m}\Delta \psi(\vec{r},t)+V(\vec{r})\psi(\vec{r},t)
with
\psi(\vec{r},t)=\varphi(\vec{r})T(t)
and when in general is that possible?
When it works!
Likes VVS2000 and topsquark
And when it works?
The separability of time dependence is a simplifying assumption in the context of the explicit time independence of the potential. But a strict condition is valid in the opposite way: If the potential is time-dependent, the assumption of splitting (separation of) variables is untenable.
Likes vanhees71 and topsquark
LagrangeEuler said:
And when it works?
Separation of variables is a general technique for solving multivariable differential equations, when we can algebraically manipulate the equation to get all of one variable on one side and all of the other variable on the other side.
The Schrodinger equation takes this form when the Hamiltonian is a function of position but not of time.
Likes LagrangeEuler, topsquark, VVS2000 and 2 others
I think it would be better to later look into how the wave function can also be represented as a product of it's "spatial" part and "spin" part
This is a widely used method to simplify multivariable differential equations..
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
