Time difference caused by length contraction
In summary, the conversation discusses the goal of calculating the difference in the passage of time between two ends of a cabin accelerating upwards due to length contraction. They refer to a study and a formula that may help with the calculations, but also note that the formula is for a system of point particles, not a cabin. They also mention the need to take into account the changing simultaneity criterion in order to accurately measure time dilation in the rocket frame.
externo
55
TL;DR Summary
Threat 3 : When a cabin accelerates rigidly it contracts in the starting reference frame. What is the calculation that gives the difference in the passage of time between the top and the bottom of the cabin?
The goal is to calculate the difference in the passage of time between two ends of a cabin which is accelerating upwards due to length contraction. To help in the calculations we can consult:
https://arxiv.org/pdf/1807.05338.pdf
There is an old problem called the 4/3 problem which has been solved by taking into account the length contraction experienced by the electron during its acceleration. When we ignore this contraction there is a difference of 4/3 between the electromagnetic mass of the electron and its electromagnetic energy, but when we take it into account the two are equal.
On page 10 we find, for the acceleration of a rigid body, the formula:
g0/g1 = 1 + hg0/c²
In our situation I believe that g0 is the acceleration of the bottom of the cabin and g1 at the top of the cabin.
With this formula one should be able to do the calculations.
What calculation specifically do you want to do? In the frame of the rocket there is no length contraction and no relative velocity. In an inertial frame there is length contraction that steadily increases over time. What specific calculation do you think relates that to the time dilation?
Likes topsquark
In the starting reference frame there is length contraction, it is therefore the difference in the proper times between the front and the back in the starting reference frame that I am looking for.
How do you intend on relating that difference in proper times due to length contraction? I mean, I can easily calculate the difference in proper times using their velocity, but length contraction doesn’t enter in at all.
externo said:
in a rigid acceleration the front and the rear do not go at the same speed, which causes a difference in the passage of time.
Yes, but how do you want to relate that to length contraction? In other words, a difference in speed doesn’t imply length contraction. I could have two objects going in different directions or even circling around each other at different speeds. They would exhibit different proper times, but not length contraction.
So how do you want to involve length contraction in the calculation? The calculation is naturally a velocity calculation not a length contraction calculation.
externo said:
Summary: Threat 3 : When a cabin accelerates rigidly it contracts in the starting reference frame. What is the calculation that gives the difference in the passage of time between the top and the bottom of the cabin?
g0/g1 = 1 + hg0/c²
First, this article mostly focuses on electrons, which have extra properties over "ordinary" matter you find in most SR problems. So most of this paper is useless to you. I'd recommend finding a good textbook on the subject.
Second, the equation you are talking about is for a system of point particles, not a cabin accelerating upward. In order for you apply this you are really doing a problem of two point particles rigidly connected by a massless rod accelerating upward.
-Dan
That's easy, then. You just look up the elapsed time along a hyperbola.
Note that the difference in proper times between front and back clocks as measured in the starting rest frame will not get you the time dilation as measured in the rocket frame unless you also take into account the changing simultaneity criterion. That's why it's a mistake to think of this as "caused by length contraction".
Likes PeterDonis and topsquark
On the rigid acceleration diagram the left world line is the back of the rocket and the right world line is the front of the rocket. The two ends do not have the same velocity because the rocket is contracting. The length contraction brings the two ends closer together, so their velocity and proper time are different.
So to be clear there are three velocities here: the velocity of the front ##v_f##, the velocity of the back ##v_b##, and the closing velocity ##v_d=v_b-v_f##. Of those, only the closing velocity has anything directly to do with length contraction.
So what exactly do you want to calculate?
Likes topsquark
Just to make sure I'm clear about what you want: at a given instant of coordinate time ##t## in the starting inertial frame, the ##x## coordinates of the front and the back will be ##x_f## and ##x_b##. You are asking for the difference in proper time elapsed along the front and back worldlines from the start at ##t = 0## to ##t##, correct?
Assuming the above is correct, what makes you think length contraction will appear anywhere in the resulting formulas?
Likes topsquark
But does the changing simultaneity have anything to do with 1 + gh/c² ? Is it the changing simultaneity which gives 1+ gh/c² or is it the length contraction? The change in simultaneity does not depend on the acceleration but on the velocity, whereas the time lag between the two ends from length contraction does indeed depend on the acceleration and could be 1 + gh/c².
Dale said:
So to be clear there are three velocities here: the velocity of the front, the velocity of the back, and the closing velocity. Of those, only the closing velocity has anything directly to do with length contraction. So what exactly do you want to calculate?
The closing velocity is only the difference between the velocity of the back and the velocity of the front. So all three velocity have something directly to do with length contraction.
Initially the proper times are t_f and t_b, with t_f = t_b.
After an acceleration, the proper time of the front and the back will no longer be identical. We will have t_f > t_b.
I'm looking for t_f - t_b.
The length contraction will not appear in the result, but the length contraction is the reason why t_f > t_b.
The changing simultaneity affects the times at which you are comparing the clocks, so of course it affects the ratio of clock rates and elapsed times.
Likes topsquark
I want calculations. I don't think changing simultaneity gives the 1 + gh/c² difference.
Why not do them yourself? All you need to do is look up the interval along a timelike hyperbola if you can't derive it for yourself. Then you consider the rates of change of interval along two such hyperbolae assuming Einstein and Rindler simultaneity respectively.
Likes topsquark
The change in simultaneity cannot exceed the proper length of the rocket. There is a relation that says :
(proper length)² - (contracted length)² = (time difference between the two ends)²
Ok, so which velocity do you want to use and what do you want to do with it?
So what calculations do you want?
Likes topsquark
We can calculate ##t_f-t_b## but:
1) it will not give the time dilation in the accelerated frame
2) there will be no length contraction involved in the calculation
3) there will be no length contraction involved in the result
Likes topsquark
1)Ok
2)Yes, the length contraction is the reason for the difference in the velocities between the back and the front, but we don't need to calculate it to find the result.
3)Ok
externo said:
2)Yes, the length contraction is the reason for the difference in the speeds between the back and the front, but we don't need to calculate it to find the result.
You claim that, but at no point will length contraction actually show up in the calculations, neither as inputs nor as outputs, nor as intermediate steps. So to claim that is the reason is very suspect.
If I say that "x is due to y" then somewhere in the derivation of x I would expect y to appear. To claim that "x is due to y" when y never shows up anywhere is unprecedented and makes no sense
Likes topsquark and PeterDonis
I believe I was wrong. What I'm looking for is not Tf - Tb, but the difference in the frequency of proper time between the back and the front of the rocket (or the bottom and the top of a cabin) at a given moment during acceleration.
I think this relation : g0/g1 = 1 + hg0/c² mus t be used.
If you want it's not due to length contraction, we'll see that later, but I think Ibix understood very well that it came from there.
https://www.physicsforums.com/threa...ed-by-length-contraction.1046087/post-6807039
externo said:
What I'm looking for is not Tf - Tb, but the difference in the frequency of time between the back and the front of the rocket (or the bottom and the top of a cabin) at a given moment during acceleration.
So this is time dilation, not length contraction, but yes this can be calculated. Are you sure you want the difference rather than the ratio?
The ratio is the best
Likes Dale
Question: Where does the velocities and accelerations difference between the rear and the front come from?
Where are you getting such a relation from? Please show your work.
Likes topsquark
externo said:
at a given moment
At a given moment according to which simultaneity convention? That of the starting inertial frame, or that of the momentarily comoving inertial frame (the latter is also the simultaneity convention of the accelerated Rindler frame)?
Likes topsquark
Where are you getting this from?
From the paper quoted in my introductory message.
What section? Page? Equation number?
  • #31
I might open another thread about it.
3.1 Relativistic description of accelerated rigid body
Page 8, 9, 10 equation 20.
  • #32
That of the starting inertial frame was my thought, but both would be best, as a matter of fact. So we can compare them.
  • #33
externo said:
That of the starting inertial frame.
Both, as a matter of fact.
The equation you reference is valid in the momentarily comoving inertial frame of the accelerated particles. More precisely, it is valid at the instant of coordinate time in that frame in which it is comoving, if, in that frame, we assign the coordinate ##x = 0## to the "back" particle (the one with proper acceleration ##g_0##) and the coordinate ##x = h## to the "front" particle (the one with proper acceleration ##g_i##).
The starting inertial reference frame is only momentarily comoving with the accelerated particles at time ##t = 0## in that frame. So the given equation is only valid in that frame at the instant ##t = 0##.
We could also treat the equation as an equation in the accelerated (non-inertial) frame in which the particles are always at rest. This amounts to using Kottler-Moller coordinates as described on this page:
https://en.wikipedia.org/wiki/Rindler_coordinates
In these coordinates, as in the momentarily comoving inertial frame, the "back" particle is at ##x = 0## and the "front" particle is at ##x = h##. The constant ##\alpha## in the metric as given in the Wikipedia article is the same as what the paper you reference calls ##g_0##, the proper acceleration of the particle at ##x = 0##.
In these coordinates, yes, the ratio of time dilation factors, i.e., of "rates of time flow", is the inverse of the ratio of proper accelerations: the rate of time flow of the "front" particle as compared to the "back" particle is larger by the same ratio that its proper acceleration is smaller. Note, however, that this property does not generalize to curved spacetime; for example, it is not true in the gravitational field of the Earth.
The above also shows that none of this has anything to do with "length contraction", since, in either the momentarily comoving inertial frame or the accelerated frame, the distance between the particles is constant; it is always ##h##.
Likes Dale and topsquark
  • #34
Here is why simultaneity matters. I have sketched a Minkowski diagram showing the worldlines of the front (blue) and rear (red) of a rocket, and added a pair of fine grey lines showing two consecutive clock ticks in the inertial frame in which the rocket was at rest at some time. In this frame, the ratio of clock rates is the ratio of proper times along the two worldlines between the grey lines (in the shaded area).
Now, here's the same diagram but showing two simultaneity planes in the rocket frame. Again, the clock rate in this frame is the ratio of the proper times in the shaded areas.
Hopefully it's obvious the red and blue lengths in the shaded areas aren't the same in the two diagrams. Apart from anything else, the value in the rocket frame will be independent of time, but the value in the inertial frame will not be. So what simultaneity criterion you use matters.
(Note that the above diagrams are an approximation - the clock rate is actually the limit of the ratio as the simultaneity planes get close to one another.)
  • #35
Ibix said:
Hopefully it's obvious these aren't the same. Apart from anything else, the value in the rocket frame will be independent of time, but the value in the inertial frame will not be.
Thanks.
The above also shows that none of this has anything to do with "length contraction", since, in either the momentarily comoving inertial frame or the accelerated frame, the distance between the particles is constant; it is always h.
In the momentarily comoving inertial frame, the distance between the particles is not constant, as you can see in the diagrams above, otherwise they would keep the same proper time. If the rocket's length is constant in the rocket's frame it cannot be constant also in the starting frame. It must contract.
