Time dilation again, Einstein or Resnick?
In summary: Both Einstein and Resnick are right, of course. Notice that Resnick's and Einsteins scenario's are somewhat different. In Einstein's scenario, one clock is first at rest relative to the other, then it moves towards the other clock. So the two clocks do not move with constant velocity relative to each other. This is somewhat unfortunate from a pedagogical point of view, it would have been better to say that both clocks all the time move with a constant velocity relative to each other, which, as I understand it, is Resnick's scenario. Einstein's version is more logical, but more difficult to understand. It is easier to see the effects of time dilation if we consider a situation in which
  • #106
jbriggs444 said:
Again, "not accelerated" is not the same as "motionless".
Motion is relative, so we cannot tell for sure if a body is in motion or not because we don't have an absolute reference frame in hand, but acceleration is absolute, so if we know a clock has accelerated, why not use that information to eliminate all the other possibilities?
  • #107
Because it is unnecessary. While you keep claiming that it is necessary.
  • #108
Mister T said:
Do you have a reference for this claim?
Einstein didn't say it this way, but he used the light clock mind experiment to explain SR, and all his space-time concept is based on the way light moves between moving bodies.
The reason I ask is that I was under the impression that the light clock is a pedagogical tool, used to explain relativity. And by the way, it is not the only way to explain it. Look, for example, at Bondi's k-calculus approach. No light clocks there!
No light clock traveling sideways to their motion in my simulation either, just light exchanged between inline moving mirrors. No need to calculate the time it takes, just to reverse its direction when it hits the mirrors and stop the watch each time it makes a roundtrip. There are often many ways to do things, but in principle, the simpler way is often the better.
Have you considered the possibility that the muon example and the twin trip example are fundamentally different? Analysis of the former involves only one measurement of proper time whereas the latter requires two.
In other words, when the twins reunite what they're comparing is the amount of proper time that has elapsed for each twin. But in the muon example there is only one amount of elapsed proper time involved, and that is the amount of proper time elapsed for the muon.
Proper time is the time that elapses between two events that occur at the same place. It's a relativistic invariant, meaning all observers will agree on its value regardless of their motion relative to it.
It actually takes the proper time of our clocks to know that the lab Muon decays faster than the atmospheric one, but we also have to know the distance the Muon had to travel before hitting the Earth's surface, thus we have to know where it started accelerating towards us.
  • #109
It is necessary if we want to make constant predictions, not to understand how light moves between moving bodies. I could have chosen not to consider acceleration in my simulation, and it would have given the same simulation, but it is the blue clock that would have suffered time dilation. From a relative viewpoint, the only thing that differentiates the clocks is acceleration.
  • #110
But the muon isn't accelerating at any point, as has been pointed out before.
  • #111
Time dilation is not the same as differential aging. No clock "suffers" time dilation ever.
  • #112
A Muon is a massive particle that has to get its speed from acceleration, so it has to accelerate from the point where it is created. It may get that speed quite fast, but it cannot get it instantly because, being massive, it has to resist being accelerated.
  • #113
You are here assuming an absolute rest frame, in contradiction to relativity.
  • #114
The thread has gone off topic and the original qustion has been answered. Thread closed.
Likes jbriggs444
  • #115
To clear up a couple of misstatements:
That problem is solved using the Sagnac effect, not relativity.
The "Sagnac effect" is not something separate from "relativity". It's a prediction of relativity.
Not if it's produced from something that already has that speed (relative to Earth, which is the "speed" you are implicitly assuming, though you have persistently refused to say so). Muons in the Earth's upper atmosphere are produced from the interaction of cosmic ray particles with air molecules. The speed the muons have relative to the Earth is the same as the center of mass speed of the system consisting of the incoming cosmic ray particles + the air molecules before the interaction. So the muons don't have to accelerate at all.
@Raymond Potvin feel free to PM me if you have questions about these responses; this thread will remain closed.
Likes vanhees71, Ibix and PeroK
