- #36
Ibix
- 14,155
Not really. They're just using an incorrect formula for the relationship between force, mass and acceleration. It's a good approximation at low speeds, but even then it's an approximation - just one that they failed to notice.PainterGuy said:So, finally, it's concluded that Newtonians would be see that more fuel has been consumed than was originally calculated. The mass increase during the trip was real.
Local time has not been dilated. I don't think that sentence means anything, to be honest. The pilot will observe that each free-floating clock is ticking slowly, but they have been mis-set so that each one is a little ahead of its predecessor giving the appearance that they, collectively, tick fast (if he hadn't noticed that each one was ticking slowly).PainterGuy said:During the trip, the pilot cannot know if local time has been dilated compared to that of the Earth and also he cannot find that mass of rocket has increased but he can definitely see the gauge and see that more fuel is being consumed than was calculated. Would the pilot be able to notice the difference?
The mass of the rocket hasn't increased - you're just using a wrong relationship between mass and acceleration.
There will be many things that the pilot could notice. Obviously, that he has to monkey around with his acceleration in order to maintain profile. That the Doppler shift of signals from Earth does not match non-relativistic predictions. The clocks, as noted above (you can't deny the pilot his heart rate as a crude onboard clock). The distance markers will not pass at the expected rate.
Yes, this is extremely confused. Length contraction has nothing to do with mass. First, just forget relativistic mass. It's nothing but a distraction - in terms of pedagogy, I think it's best described as an attempt to pretend that relativity isn't more complicated than Newtonian physics. Which is blatantly untrue and comes back to bite, hard, later on.PainterGuy said:To me, two different concepts are being mixed up by the term 'length contraction' here. When mass is moving really fast, it gets deformed and it results into the length contraction of mass. But at the same time when a mass is moving really fast, the distance traveled by it also gets shortened due to the time dilation so this is another type of length contraction involving 'distance traveled'.
Furthermore, length contraction and time dilation don't cause one another. Nor does the constancy of the speed of light cause time dilation. I strongly suspect that your problem here is that you are attempting to reason about relativity based on time dilation and length contraction, which are special cases of the Lorentz transforms, in circumstances where they do not apply. I think this because length contraction is not two phenomena, and you have not mentioned the Lorentz transforms at all.
