Time for astronaut to reach the satellite
An astronaut needs to reach a satellite 50 km ahead by lowering his orbit by 2 km while both are in a circular orbit 400 km above Earth. The calculations involve using the Law of Universal Attraction and centripetal force equations, but the astronaut's initial calculations yielded a time of approximately 1.5 hours less than the book's answer. After correcting a mistake in the formula, the recalculated time was found to be around 12.3 hours, which is closer to the book's answer. The discussion emphasizes the importance of deriving a clean formula for solving physics problems. Ultimately, the focus is on achieving accurate calculations for the time needed to reach the satellite.
Gebri Mishtaku
So I found this problem in my 10th grade Physics workbook and since its test time tomorrow I must be able to work everything out. The problem I'm having here is just the calculations which give me a time short of one hour from the answer on the book. Anysways, please have a go:
An astronaut is flying on a shuttle that's on the same orbit(400 km above the surface of Earth) as a satellite that he needs to repair. He is 50 km behind the satellite and in order to reach it, the astronaut lowers his orbiting radius by 2 km. What is the time needed for the astronaut to reach the satellite?
It doesn't say anything about it being an aerial distance, so it must be taken to be circular.
G=6.67x10^-11Nm^2/kg^2
MEarth=6x10^24kg
REarth=6.4x10^6m
The equation for the Law of Universal Attraction must be used and also that of the centripetal force and acceleration in circular motion:
Fc=mv^2/r and FG=(Gm1m2)/r^2
I tried going around this problem calculating the relative linear speed of the astronaut to the satellite and then the time of approach would just be the ratio of the distance the astronaut had to travel relative to the satellite(50km) with the astronaut's relative linear velocity. I know I'm missing something here because my calculations(which in this problem are loathsome to be honest) come out ≈ 1.5 hours less than the answer on the book, which wouldn't surprise me if it was wrong because this book has plenty of mistakes in it.
Formula and answer are found in the attachment.
It does not look good.
The expressions under square roots are accelerations (F/m). Taking the square root does not produce a velocity as you should have in order to get t from that formula.
Oh I am so sorry the formula for t had a writing mistake in it. I had wrote the R^2 in the denominator inside the square roots mistakenly. Now I reuploaded the attachment to amend it. I had calculated for R not R^2 though, so it's all fine in that aspect.
Using your numbers in your formula I get 12.3 hours, which is close the book's answer. Not sure how you get 10.7 hours.
OMG THANK YOU SO MUCH! For me, a physical problem ends when there is found a final formula that has everything known on the right side and the unknown on the left so as far as that goes I seem to be right. Getting a nice and clean formula in the end is the most exhilarating thing for me! The rest I think is computer-plug-and-chug. Thank you again for your time.
OK, Good work!
Likes 1 person
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
