Time-independent Schrodinger equation in term of the TDSE
The discussion centers on interpreting a homework question regarding the general solution of the time-dependent Schrödinger equation (TDSE) in terms of the time-independent Schrödinger equation (TISE). Participants clarify that the solution can be expressed as a summation involving time-dependent coefficients and eigenfunctions, but emphasize that these coefficients should not depend on time to satisfy the TDSE. The method of separation of variables is highlighted as a valid approach, leading to the conclusion that any initial wave function can be represented as a combination of TISE solutions. The conversation reflects on the importance of understanding the linearity of the Schrödinger equation and the implications for the coefficients in the solution. Overall, the discussion aims to clarify the relationship between TDSE and TISE solutions.
rwooduk
Write down the general solution of the time-dependant schrodinger equation in terms of the solutions of the time-independant Schrodinger equation.
TDSE
TISE
I'm really not sure how to interpret this question, I could write the general solution to the time dependant schrodinger equation:
\Psi (r,t) = \sum_{n} a_{n}(t) \Psi _{n} exp (-\frac{iE_{n}t}{\hbar})
insert this into the time dependant schrodinger equation and show that it is satisfied, i.e. equal at both sides
OR
Does it want me to write ψ(r,t) = R(r)T(t) insert this into the time dependant schrodinger equation and use separation of variables to show that there are two solutions, one with time and one with position dependance.
Thanks for any help interpreting what the question is asking me to do.
Your problem statement has independent twice.
I think what you did is fine if you reconsider the ##a_n(t)## :
you want to give expressions for them
if they are functions of t the whole idea of separation of variables is up the creek​
Yes apologies it should have read:
So if i insert
into the time dependant schrodinger equation and show that it is satisfied, do you think that's what the question is asking me to do?
also how would i expand an(t)?
many thanks for the reply
Still won't work because you want ##i\hbar\;{\partial \Psi\over \partial t}=E\;\Psi## and ##da\over d t## spoils that...
[edit] :oops: sorry, that's for the ##\Psi_n##, not for ##\Psi (r,t)##. Nevertheless, I think you don't want the ##a_n## time dependent. No time to dig up a reasonable argument now. Have to think that over.
That's fine, I appreciate the help anyway. I will also think on it some more and post if I get anywhere. I look forward to any further ideas you or anyone else may have on this one.
The TISE comes about by separation of variables: split ##\Psi ({\bf r},t) = f(t) \Psi ({\bf r})##. For f(t) the separated eqn becomes ##\displaystyle {i\hbar\over f}\; {df\over dt} = E##.
Linearity of the SE allows coefficients ##a_n##, but there is no room in f(t) for functions ##a_n(t)##.
Likes rwooduk
ahh, ok so it's what I was thinking in the second part of the original post. That's great, thanks very much for the help!
Depending on where you are in the curriculum, there's more that can be loaded onto this exercise:
showing that any ##\Psi({\bf r},0)## can be written as such a summation (i.e. that the ##\Psi_n## form a basis),
the expressions for ##a_n##, etc
Likes rwooduk
We have done both, which is why I found the question so disambiguous, if both methods show the same thing I'll go with the separation of variables method.
thanks again
