I Time Reversal Breaking in Classical Systems
Examples of classical systems lacking time reversal symmetry include chaotic systems and those with friction, such as a damped pendulum. Non-reciprocal optics and electromagnetic nonreciprocity are also cited as relevant examples. Systems that experience loss inherently exhibit time-reversal asymmetry. The discussion raises questions about the effects of time reversal on closed systems under external magnetic fields. Overall, the exploration highlights the complexities of time reversal in classical physics.
hokhani
TL;DR Summary
Classical systems without time reversal
I am looking for an example of a classical system without time reversal symmetry. I would appreciate any help.
hokhani said:
Summary:: Classical systems without time reversal
Classical physics is symmetric under time reversal. Entropy is the only arrow that I know of classically.
As example of classical systems that exhibit behavior that (in some practical sense at least) is not quite symmetric regarding time reversal I guess you could look at chaotic systems.
the banal pendulum with friction
$$\ddot x+x=-\dot x$$
is not invariant under the change ##t\mapsto -t##
Check out "non-reciprocal optics" or " electromagnetic nonreciprocity".
Any system with loss is also time-reversal asymmetric.
Thank you all for the responses. How about a closed system which is under an external magnetic field? Does time reversal change also the external magnetic field or it only reverses the time in the closed system?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
