Andrew Howe
- 4
Hi.
I'm doing a KS3 coursework experiment whereby I need to investigate the question, 'Does the area of a parachute affect the rate of fall?' Obviously the answer is yes, however the theoretical physicist within me wanted to take this much further, so I attempted to pull together my basic understanding of drag, air resistance etc. in order to come up with a formula. I am using square parachute material made out of standard polyphene shopping-bags attatched to a spherical 1g weight of plasticine via. cotton. I am not taking into account the drag of the weight or cotton or the weight of the parachute material or the cotton, each of which I believed were neglieable. I came up with the formula seen in 'parachute2.JPG'. What I was trying to find, as explained better in 'Basicfor.JPG', was the length of time it takes for the parachute to reach its terminal velocity plus the time it takes for the parachute to travel the rest of the distance to the floor.
In the formula:
b = total time taken (seconds?)
m = mass of weight attactched to parachute (in kg?)
g = gravitational force (9.81?)
C = numerical drag coefficent (1.28 for a flat plane?)
p = air density (0.0022 approx.)
A = crossectional area (cm sqaured?)
'9.81' = acceleration under the affect of gravity (metres/second squared?)
d = total distance from where parachute was dropped from to floor (cm?)
u = initial velocity of parachute (zero m/s)
t = time taken
a = acceleration (9.81 m/s squared?)
Firstly, is this formula correct? And secondly, are the units correct? I would appreciate any help in this matter.
In the formula:
t = time taken
