ghwellsjr said:
We can measure time-like spacetime intervals using a single inertial clock that passes through both events. This does not require any synchronization convention since there is only one clock and it does not require any ruler.
However, for space-like spacetime intervals, even though we are measuring it with a single ruler, it is not sufficient that two points on that ruler pass through both events, they must pass through at the same time as determined by two synchronized clocks located at the two points of measurement.
this is a good example of what I am talking about. right, so let's say we have defined what are the time-like intervals. And 'normal' matter all moves along these time-like intervals. So now, we can use some normal matter to measure any time-like spacetime interval. (for example, a muon beam acts a very good clock, since the muon's mean lifetime is accurately known). i.e. we send a muon beam along a time-like interval, and the fraction remaining tells us the arc length along that path.
But now, suppose we come across some not-normal matter that moves along a space-like interval. Again, suppose it is like a muon, i.e. the amount of muons that decay depends only on the arc length that the beam has traveled. Now, we could use this weird matter to measure the arc length along a space-like interval, simply by observing the fraction of muons that remain, since this tells us the arc length along that path.
