Admissions Tips for a CS and physics major
  • Thread starter Thread starter ricke7s
Undergraduates pursuing degrees in computer science and physics should focus on relevant coursework for their desired graduate programs, particularly if aiming for a PhD in physics. While a double major may not significantly impact applications, having a strong foundation in physics and computational skills can be beneficial for research in quantum fields. Engaging in undergraduate research is crucial, with an emphasis on finding projects that align with personal interests and working closely with mentors. Prioritizing advanced physics courses and research experiences over a double major may enhance preparedness for graduate studies. Ultimately, a solid understanding of core physics concepts and practical research skills is essential for success in graduate applications.
ricke7s
Hello, I’m an undergraduate student pursuing degrees in both computer science and physics. I was wondering if anyone here has graduated with these degrees and applied to a physics graduate program. I’m curious about how graduate programs evaluated your applications. In addition, if I’m interested in doing research in quantum fields related to materials or computational physics, what kinds of undergraduate research experiences would be most valuable?
What country are you in? By "graduate program" do you mean master's or PhD?
PhD and I reside within the USA
The fact that you're double majoring likely won't factor in too much. They'll want to know whether you have the necessary coursework for the specific program you're applying to. Usually the double major just means that where other applicants will have a wider breath of options that they've taken, you will have focused yours in such a way that you've covered the core material for the other major. Sure, a computer science second major is likely to be helpful for getting into a sub-field that's heavy on the computational side, but most physics majors will have had some computing and numerical methods training.
When it comes to undergraduate research experience the specific field tends not to be as important as what you do with the opportunities that you have. In my experience it's a lot more important to find a project that you're passionate about and a mentor that you gel with and learn the ins and out of how to set up a long term research project, how to make incremental progress and systematically track it, how to analyze and write up the results, etc.
What year are you in? If you are confident that you intend to pursue a Physics PhD program, there's not much advantage in pursuing a double major. You'd be better off taking some CS courses as electives, and spending more time on advanced undergrad physics courses or undergrad research. E.g., if you are interested in materials, you want to take at least a solid-state physics course.
On the other hand, if you're not quite sure, a degree in CS could serve as a good Plan B backup.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
