Tips for factoring quadratic expressions
In summary: So the overall strategy is to group the coefficients of the Quadratic Equation (ie. the exponents) and then use the Order of Operations to Factoring.
MarkFL
MHB
13,288
The purpose of this tutorial is to provide students of algebra with techniques and tips for factoring quadratic expressions. In my experience as a tutor, I have found this can be one of the more difficult and challenging topics for students.
I invite anyone with any techniques of their own to add to this topic to give our readers as comprehensive a list of tips/tricks as possible.
Note: all coefficients, both in the quadratic forms and in the factored forms are integers.
Typically, a quadratic expression is given in the form:
(1) $ax^2+bx+c$
and the goal is to express this expression as the product of two linear factors:
$ax^2+bx+c=(dx+e)(fx+g)$
First of all, students may wonder why we bother to factor quadratics. Well, this has to do with what's called the zero-factor property. Many times in the application of quadratic equations, we express the equation in standard form $ax^2+bx+c=0$. In short, if we have two factors equal to zero, then we know that the product must be zero when one or the other of the factors is equal to zero. Since finding the root of a linear factor is very straightforward, this gives us a neat and easy way to find the two roots of the quadratic expression.
The way I begin, is (referring to (1)) by looking at the product $ac$ and try to find two factors of this product whose sum is $b$.
Suppose we are given to factor:
$x^2+8x+12$
The product $ac=1\cdot12=12$ so we want two factors of $12$ whose sum is $8$. Thinking about the factor pairs of $12$ which are $(1,12),\,(2,6),\,(3,4)$ we see the pair $(2,6)$ has a sum of $8$. Since $a=1$, we know the coefficient of $x$ in both factors will also be $1$, and so we have:
$x^2+8x+12=(x+6)(x+2)$
If we're unsure, we may check our work by expanding the right side using the FOIL method:
$(x+6)(x+2)=x^2+2x+6x+12=x^2+8x+12$
So, it checks out. Why does this method work? Let's do a bit of investigation:
To keep things simple for now, let's consider the case where $a=1$:
$x^2+bx+c=(x+d)(x+e)=x^2+ex+dx+de=x^2+(d+e)x+de$
Equating coefficients, we find we require:
$d+e=b$
$de=c$
As you can see, this implies we need to find two factors of $c$ whose sum is $b$. This is why we look for two such factors.
Now, let's step things up just a bit and let $a$ be a prime number. Since a prime number only has itself and $1$ as factors, we know the factored form must be:
$ax^2+bc+c=(ax+d)(x+e)=ax^2+(d+ae)x+de$
So, we see now, we require:
$d+ae=b$
$de=c$
If we mutiply the second equation by $a$, we may write:
$d(ae)=ac$
So, these equations imply that we need two factors of $ac$ whose sum is $b$. Let's now apply this to the quadratic:
$3x^2-13x-10$
We want two factors of $3(-10)=-30$ whose sum is $-13$. These are $(2,-15)$. Since $a=3$, we look for the factor that is divisible by $3$ and that is $-15$. So we set:
$ae=3e=-15,\,e=-5$
$d=2$
and so we now have:
$3x^2-13x-10=(3x+2)(x-5)$
Now, let's examine the case when $a$ is composite, which means there is more than 1 possible factor pair of $a$, and so we need to write the factored form as:
$ax^2+bx+c=(dx+e)(fx+g)=dfx^2+(dg+ef)x+eg$
Equating coefficients, we find:
$df=a$
$dg+ef=b$
$eg=c$
If we multiply the first equation by the third, we have:
$(dg)(ef)=ac$
This, along with the second equation above implies we need two factors of $ac$ whose sum is $b$. Suppose we are given to factor:
$6x^2+13x-28$
We want two factors of $6(-28)=-168$ whose sum is $13$. They are $(-8,21)$.
Now, we look at the factor pairs of $6$ which are $(1,6),\,(2,3)$. Neither of the pair $(-8,21)$ is divisible by $6$, but $-8$ is divisible by $2$ and $21$ is divisible by $3$, so the factor pair of $6$ we need is $(2,3)$. And so we find we may set:
$d=2$
$f=3$
$dg=2g=-8\,\therefore\,g=-4$
$ef=3e=21\,\therefore\,e=7$
and so we have:
$6x^2+13x-28=(2x+7)(3x-4)$
Commentary to this tutorial should be posted here:
http://mathhelpboards.com/commentary-threads-53/commentary-factoring-quadratics-4203.html
Moderator edit: This commentary topic pertains to the following tutorial:
http://mathhelpboards.com/math-notes-49/factoring-quadratics-3396.html
I agree with everything MarkFL has posted so i'll just give a quick 'scheme' leaving out the details.
Another approach is to factor by grouping, consider,
$6x^2 - 17x - 45 $
$(6)(-45) = -270$
Now find 2 integers that multiply to -270 and sum to -17,
-27 with 10 work
rewrite $-17x$ as $-27x + 10x $
$6x^2 - 27x + 10x - 45 $
use grouping, paying mind to the signs,
$ (6x^2 - 27x) + (10x -45)$
factor,
$3x(2x - 9) + 5(2x - 9)$
$(2x - 9)(3x + 5)$
You can multiply this out using FOIL to confirm the factoring is correct.
Re: Factoring Quadratics
agentmulder said:
$6x^2 - 17x - 45 $
$(6)(-45) = -270$
-27 with 10 work
How to do it:
We have to find p and q such that pq=6 x (-45)= 2 x 3 x 3 x 3 x 5
and p+q=-17
We observe that 17 is a prime.So p and q cannot have common factors (otherwise p+q will be have a common factor).
So either p or q will have all the 3 "3"s.Let it be p.
We have a 2 and 5 remaining which can go into either p or q.Let us first try both of them in q.
So we have p=27 and q=10
One and only one of p and q is negative and also the greater of p and q has to have the sign "-" (because the sum is negative).
So we have p + q = -27 + 10 = -17 and it works.If it hadn't worked then we had to exchange the 2 and 5 a couple of times until we get it right.
If p + q had a common factor,then we had to allow it to be the GCD of p and q and continue this.
mathmaniac said:
How to do it:
and p+q=-17
These are nice observations, i especially like the part of all 3's must belong to p or q. As the product AC gets large your observations can in fact reduce the work involved trying to find p and q.
Hello,
I can add a method :)
Let's say we want to factor \(\displaystyle p(x)=-4x^2+24x-32\) we can use this formula \(\displaystyle p(x)=k*(x-a)(x-b)\)
we want to calculate crittical point (without derivate). In Sweden we learned a formula caled "pq-formula"(too calculate critical point in second polynom) as you can see there can't be any number or negative number infront of \(\displaystyle x^2\) so we start to break out -4 then we got \(\displaystyle -4(x^2-6x+8)\)
now we calculate the critical point \(\displaystyle x^2-6x+8=0\) and we get \(\displaystyle x_1=4\) and \(\displaystyle x_2=2\) now we use the formula \(\displaystyle p(x)=k*(x-a)(x-b)\) where k is our constant and a,b our crit point so we got \(\displaystyle p(x)=-4*(x-4)(x-2)\)
here is pq formula:
image.php
FAQ: Tips for factoring quadratic expressions
How do I know when an expression is a quadratic?
An expression is quadratic if the highest exponent of any variable is 2. This means that the variable is being squared. For example, x^2 + 3x + 2 is a quadratic expression while x^3 + 2x + 1 is not.
What is the general form of a quadratic expression?
The general form of a quadratic expression is ax^2 + bx + c, where a, b, and c are constants and x is the variable being squared. It is also known as the standard form.
How can I factor a quadratic expression?
One method for factoring quadratic expressions is by using the "AC" method. This involves identifying the values of a and c in the general form, and finding two numbers that multiply to equal ac and add to equal b. These two numbers can then be used to rewrite the expression in factored form.
Can quadratic expressions have more than two terms?
Yes, quadratic expressions can have more than two terms. However, they must contain a term with an exponent of 2 to be considered quadratic. For example, x^2 + 3x + 5 and 2x^2 + 4x + 7 are both quadratic expressions with more than two terms.
Why is factoring quadratic expressions important?
Factoring quadratic expressions is important because it allows us to simplify and solve equations, find the x-intercepts of a graph, and identify the roots of a quadratic equation. It is also a fundamental skill in algebra that is used in more advanced mathematical concepts.
