Tips for Solving a 1D Second Order ODE in an Open Channel Experiment
Beniguette
Hi all,
My maths are very rusty and I would need some advice. I have some experimental results obtained in an open channel and got depth-averaged velocity u(y) at different cross-sectional locations y. I tried different models but there is one I don't know how to tackle. The following one dimensional second order ODE describes the evolution of u(y):
<br /> a^{2}-b^{2}u^{2}+c^{2} \frac{du}{dy}+e^{2}y\frac{du}{dy}+f^{2}y^{2}\frac{d^{2}u}{dy^{2}}+r^{2}y\frac{d^{2}u}{dy^{2}}<br />
I tried the dsolve function in Matlab, even putting some numbers in the constants without success. I don't really need an analytical solution (is it likely there would be any?). I have the experimental results and want to adjust part of the constant r to see how some parameters affect the results. Boundary conditions are known from experiments. Do I need to discretise that equation to get a solution? How should I do that?
I really welcome any advice or suggestion.
Regards,
Ben
Have you tried using the series method? Except for the u^2 term, the rest is pretty easy to treat in this manner. You might get some useful information that way.
No. Series solutions depend on the fact that you can add solutions of a linear equation to create a new solution. That isn't true for non-linear equations so series solutions don't work for non-linear equations.
Thank you for your interest scorpion990 and HallsolIvy. I have read someone mentioning he used a Newton iteration method to solve the same type of ODE in a similar context. He starts with an assumed profile of U(y) and an initial guess for the unknown parameter r. In each iteration the value of r at the previous time step is used as a known constant. He states that the profile evolves to a final form that is independant from the original profile. Does that make sense to anyone?
Since you don't mind numerical solution, try making the substitution v=du/dy. You then solve the system of differential equation.
\frac{du}{dy}=v and
\frac{dv}{dy}=\frac{-a^2+b^2u^2-c^2v+c^2yv}{f^2y^2+r^2y}
Please refer to the thread: Laser rate equation(ODE) simulation problem
if you want to try solving with matlab.
I've just moved house and had no access to the Internet so I'm just getting your post. Thanks a lot for the suggestion matematikawan, that seems like an interesting read. I shall give it a go.
