Titan implosion: underwater shockwave?
The Titan submersible's implosion likely generated a shock wave, potentially affecting marine life in a manner similar to dynamite fishing, with a significant kill radius. The energy released during the implosion is estimated to be equivalent to detonating around 100 kilograms of TNT, based on calculations of pressure and volume. Claims about the internal temperature reaching that of the sun's surface are exaggerated; a plausible increase would be around five times the original temperature, reaching approximately 1200 degrees Celsius. The implosion's timing suggests it occurred hundreds of meters above the seafloor, which would not have caused an underwater sandstorm, but if it had, the sand would take time to settle. Expert analysis is required for precise details on these phenomena.
Lieutenant Barclay
Like many I’ve been captivated by the Titan story. I’m wondering a few things:
1. Was a shock wave cause by the implosion?
2. Would marine life have been killed similarly to “fishing w/ dynamite”? Kill radius?
3. A TV talking head claimed the inside of the vessel would have heated to “a temp the surface of the sun” for a fraction of a second - true or BS?
4. How much energy was released when it imploded?
5. I read Rush tested a 1/3 scale model in a chamber at U Washington. Supposedly the test implosion shook the building and blew out the sensors. Can anyone link to a picture of the kind of chamber used for these tests?
Finally, timing indicates the implosion did not take place on sea floor but rather hundreds of meters above. If it HAD happened on the sea floor, would it have caused an “underwater sandstorm” i.e. temporarily block visibility from kicking up so much sand? How long would the sand have taken to settle?
RIP to the 5 souls lost.
That will be the product of the pressure and the volume imploded.
In back-of-the-envelope numbers…. Say that the volume of the Titan was about ten cubic meters, pressure at the ocean bottom 400 atmospheres or ##4\times 10^7## Pascal, the explosive TNT releases about 4000 Joules per gram, we’re talking roughly the equivalent of detonating one hundred kilograms of TNT.
The surface of the sun isn’t that hot, about 6000 degrees Kelvin. Figure the interior of the submersible was at about 300 K…. With no time to dissipate heat a twenty-fold temperature increase during the energy release is quite plausible.
Likes Klystron, russ_watters and Borg
Not by my back of the envelope calculations.
The contents of the submarine were air. Not helium or other inert (monoatomic) gases. That leaves adiabatic exponent 1,4.
Which means that compressing air to 1/32 (1/25) initial volume should raise its temperature 4 (22) times and pressure 128 (27) times.
The pressure will have been limited by the sea pressure (under 400 bar). And the other thing limiting heating is nonideality of compressed gases. Thew compressibility of gases drops off drastically above 100 bar as their density and properties approach liquid ones. Gases above 200 bar are little compressed by further pressure - and little heated.
Say it reaches 5x original temperature... that would be just 1200 Celsius?
It had to.
Let's imagine the sub is a sphere of about 2.25 meters. (The actual volume of the Titan was 47 m³.)
Let's imagine the speed at which the sub collapses is at the speed of sound (in air). The initial speed would have been 1200 km/h and, as the temperature increases 5 times (per @snorkack 's post), it would have reached 2700 km/h by the end of the process. Let's assume an average velocity of 2000 km/h.
The velocity of the water displaced will drop around the sub as the distance increases per the sphere area ratio, i.e. the radiuses ratio squared. Compared to our initial radius of 2.25 m, at a 22.5 m distance, the velocity would drop to 2000*(2.25/22.5)² = 20 km/h. This would begin to feel like a light breeze to anyone at this distance from the sub. At 10 m, you would feel a 100 km/h water wave rushing through you, which must be pretty wild.
Likes pinball1970
jack action said:
It had to.
Hi Jack,
Could do with your input on the other Titan thread. It is an engineering/ acoustic question. @russ_watters and @Baluncore and @aorlanda can help?
Thread 'RIP Chen Ning Yang (1922-2025)'
https://en.wikipedia.org/wiki/Yang_Chen-Ning ( photo from http://insti.physics.sunysb.edu/~yang/ ) https://www.nytimes.com/2025/10/18/science/chen-ning-yang-dead.html https://www.bbc.com/news/articles/cdxrzzk02plo https://www.cpr.cuhk.edu.hk/en/press/mourning-professor-yang-chen-ning/ https://www.stonybrook.edu/commcms/physics/about/awards_and_prizes/_nobel_and_breakthrough_prizes/_profiles/yangc https://www.stonybrook.edu/commcms/physics/people/_profiles/yangc...
Thread 'In the early days of electricity, they didn't have wall plugs'
Hello scientists, engineers, etc. I have not had any questions for you recently, so have not participated here. I was scanning some material and ran across these 2 ads. I had posted them at another forum, and I thought you may be interested in them as well. History is fascinating stuff! Some houses may have had plugs, but many homes just screwed the appliance into the light socket overhead. Does anyone know when electric wall plugs were in widespread use? 1906 ad DDTJRAC Even big...
