Toroid with Air Gap magnetostatics problem
The discussion revolves around solving a magnetostatics problem involving a toroidal electromagnet with an iron ring and an air gap. The objective is to determine the magnetic field intensity H within the iron, using Ampere's law and boundary conditions for the magnetic field B. The initial calculations yielded an incorrect expression for H, prompting further exploration of the relationship between H in the air gap and the iron. The continuity of B across the air gap and iron interface is emphasized, along with the need to express H values separately for both regions. The conversation highlights the importance of understanding the discontinuity in H due to magnetic pole density and suggests that using a modified form of Ampere's law simplifies the analysis.
Tinaaaaaa
consider a toroidal electromagnet with an iron ring threaded through the turns of wire. The ring is not complete and has a narrow parallel-sided air gap of thickness d. The iron has a constant magnetization of magnitude M in the azimuthal direction. Use Ampere's law in terms of the magnetic field vector H, along with the boundary conditions on B and H at the interface, to show that the magnitude of the field H within the iron at a distance r from the centre of the ring is given by
Hiron=(NI-Md)/2πr[/B]
B=μ0(M+H)
490c264a64e44d7dd31713dd6a7fa3c0c1e520aa
- Ampere's Law
So far I have calculated the B field in the closed toroid which would be, using Ampere's integral law: B=μ0ΝΙ/2πr.
Based on that plus the fact that Bair⊥=Biron⊥, we assume that for the air the B is the same. Thus, I equated
B=μ0(M+H)→(B-μ0M)/μ0=H→H=(NI-M)/2πr
This is clearly not the correct answer so I would appreciate it if you could please show me how to reach the correct answer.
You need another form of Ampere's law which is ## \oint H \cdot dl=NI ##. The ## H ## is not continuous though in this problem, while the ## B ## is assumed to be continuous. ## H ## will take on a different value in the air gap=call that ## H_1(r) ##, and ## H_2(r) ## will be the value in the iron. Expressing the continuity of ## B ## at a distance ## r ## from the center: ##B(r)=\mu_o H_1(r)=\mu_o (H_2(r)+M) ##. ## \\ ## Next, write ## \oint H(r) \cdot dl =NI ## in terms of ## H_1(r) ## and ##H_2(r) ##, and then with just ##H_2(r) ## by substituting in for ##H_1(r) ##. With these hints, you should be able to complete it, by solving for ## H_2(r) ##. ## \\## Note: The standard form of Ampere's law is ## \oint B \cdot dl=\mu_o I_{total} ## where ## I_{total}=I_{conductors}+I_{m} ##, where ## I_{m} ## is from magnetic currents and magnetic surface currents. The ## I_m ## requires extra computation, and it is far simpler to just use ## \oint H \cdot dl=I_{conductors}=NI ##.
Thank you!
Likes Charles Link
I should point out, in the pole theory of magnetism, there is a good reason for the discontinuity in ## H ##. Magnetic pole density ## \rho_m ## is given by ## \rho_m= -\nabla \cdot M=\nabla \cdot H ##. This makes a magnetic surface charge density on the end faces at the gap given by ## \sigma_m =\vec{M} \cdot \hat{n} ## which are sources of ## H ## that result in this discontinuity. The calculation can also be done with this surface charge density ## \sigma_m ## and Gauss's law, but using Ampere's law in the modified form, and simply assuming an ## H_1(r) ## and an ## H_2(r) ## allowed us to sidestep this calculation, which would be found to be in complete agreement.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
