Idea04
- 194
- 1
I need someone to clarify for me how an increase in torque angle in an ac generator increases the power factor. Does the torque from the rotor force the current in phase with the voltage on the stator.
Torque angle refers to the angle between the stator and rotor magnetic fields in a generator. It is an important factor in determining the efficiency and power output of a generator.
A larger torque angle can result in a decrease in power output, as it causes a misalignment between the stator and rotor magnetic fields, leading to a decrease in the generator's efficiency.
Power factor is a measure of the efficiency of a generator, indicating how much of the electrical energy produced is converted into useful work. A higher power factor indicates a more efficient generator.
Torque angle can affect the power factor of a generator, as a larger torque angle can result in a decrease in power factor, indicating a decrease in efficiency.
The design and construction of the generator, as well as external factors such as load and operating conditions, can all influence the torque angle and power factor of a generator.
