Torque calculations: Rotating vertical shaft
A vertical shaft operating at 600 rpm is supported by two angular contact ball bearings and rotated by a motor through a belt drive with a 1:1 transmission ratio. The torque required by the motor includes inertial torque and frictional torque from the bearings, with calculations for moment of inertia and angular acceleration provided. The discussion highlights the need to calculate radial loads on the bearings and considers the impact of bearing orientation, preload, and other loads beyond axial weight. Participants emphasize the importance of a complete diagram to clarify the setup and forces acting on the bearings. Additional considerations such as belt efficiency and safety factors will be addressed after determining the required torque.
Gagan
I apologize in advance for any errors in my concepts or assumptions. Feel free to correct me wherever I am wrong. Thanks in advance for the help.
There is a vertical shaft which will be operated at around 600 rpm (N) which can be achieved in 2 seconds (or even 4 just an assumption). The shaft is held by two angular contact ball bearings. I have attached a sketch for further clarification on how the setup looks like (sorry for the bad sketch). The shaft is rotated by a motor via a belt drive mechanism. The pulley radius on both shaft and motor is same so the transmission ratio is 1:1. Shaft material is AISI304.
I need to calculate the torque required by the motor to rotate this shaft which is summation of all the torques generated by the rotating shaft.
The shaft weights 0.7-0.8 Kg. Each bearing weighs 0.15 Kg. I don't know if the weight of the housing is also relevant or not but it is 4 Kgs incase it is required. I already calculated torque due to inertia which is pretty straightforward as follows:
T (in) = I * α
Moment of inertia (I) = 0.5 * MR^2 (if solid, in reality it is hollow but keeping the calculations simple for now)
angular velocity: ω = 2π N /60 = 20π rad/s
angular acceleration: α = dω/time = 10π rad/s^2
Now, since we know this is not the only torque which motor has to resist, there are frictional torque generated by both the bearings. The formula for frictional torque can be approximated for angular contact bearings to:
T (fr) = 0.5 * μ * radial load (N) * bearing bore (m)
μ = 0.002 for angular contact ball bearings (this is low because there is lubrication and non-contact seals) so the frictional force in reality acting between shaft and the lubricant
(Source: https://www.amroll.com/friction-frequency-factors.html)
I calculated the radial loads acting (perpendicular) on bearing face from rotating shaft considering they are centrifugal but I am assuming I am wrong here. I do know, this is very less and can be neglected but I am considering it because it can be significant relative to the inertial torque. I want to know how I can calculate the radial loads acting on the bearing. Also, if there are any other loads acting on the bearings (apart from axial load i.e. mass * gravity), you're welcome to tell me
I know there are other considerations like belt transmission efficiency (80-90%) , safety factor (2-2.5) etc. But, I will account for them at the last once I have the required torque (from inertia and friction). Nevertheless, do tell me if there are any other crucial considerations that I should account for.
Feel free to make assumptions (can consider shaft with same cross-section diameter all along the length) because I am looking for assistance on concepts, formulas and how I should approach the problem. All the other details (relevant or not) can be seen in the sketch.
Thanks
Gagan Jain
Welcome to PF.
You do not show the orientation of the angular contact faces of the two bearings.
I expect the lower one will carry the weight of the rotating shaft, while the upper will provide an opposed preload that aligns and positions the shaft. The specified preload will appear twice in the friction computation.
Baluncore said:
Welcome to PF.
Thank you!
The orientation is back-to-back arrangement (that is indicated by the dotted lines in my sketch) (reference image attached) if that is what you meant by orientation. Yes, you are right but I am not aware of which is what since the setup was manufactured way before I started working on it. One of them is a locating bearing i.e. fixed side to position the shaft axially and the other is a non-locating bearing i.e. free side (radial clearance exists in between the housing and outer race) to compensate for shrinkage or expansion. But, I anyway think your guess is correct, lower one is non-locating and upper one is locating.
Regards
Gagan Jain
There are many ways of stacking multiple angular contact bearings to optimise load handling, alignment control, or convenience of assembly-disassembly. The original diagram was confusing because the dotted line could be through the two ball contact points, or tangent to ball at the contact surface.
Since the two bearings are on the same side of the steps, and you do not show the housing, I have to assume there is something not shown that stops the shaft falling out of the machine. That other something will offer preload. You have minimised the diagram and hidden half the reaction forces.
Okay, I get you now. So, there is a common housing for both the bearings and it is clamped on by 4 bolts fastened to a vertical flat plate. I hope this gives clarity.
No.
Both which bearings ?
What does the clamp plate act against ?
I think you need a more complete diagram.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
